Go Back   HondaCivicForum.com > Your Ride > Engine & Internal > Swap Meet > ED-EF Swaps
Reply
Old 01-20-2007, 03:44 PM
97civic707 97civic707 is offline
My Garage
Default mini me help
ok so i got a 91 si and i wanna do a mini me. will my valve cover intake manifold and all that work. i know my dizzy wont unless i do some fab work. also if u use a p28 ecu and get the conversion harness will my injectors and sizzy work or do i need to still put on the resistor box and get a obd1 dizzy. thanks for the help
Sponsored Links
Old 01-30-2007, 08:25 PM
civtec00 civtec00 is offline
My Garage
Default RE: mini me help
what motor are you using? d16z6, or the d16y8? the intake manifold from your d16a6 motor will fit on both motors but the d16y8 doesnt have the hole for the intake air temp sensor on the manifold, im not sure about the valve cover because i think that the d16a6 plugs are on the other side of the cover, than the d16z6, d16y8
__________________
1969 chevelle 350 4 speed
1990 civic hatchback dx b18b 5 speed
1990 civic hatchback dx d15b2 turbo 4 speed
1989 civic hatchback si 5 speed
Old 01-31-2007, 11:11 AM
finalimpact finalimpact is offline
My Garage
Send a message via AIM to finalimpact Send a message via Yahoo to finalimpact
your valve cover will not work. and with an obd1 conversion....you can still use yoru factory injectors assuming you leave the resistor box in place. as for the dizzy you will have to get an obd1 dizzy.
__________________
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
