18,000 Rpm EG6 ?
RE: 18,000 Rpm EG6 ?
Timing is off but I like the sound
thats fake. to make that much power up that high the ports would have to be custom and perfect along with some serious custom work with tripple valve springs. sounds just like an f1 dub over
ORIGINAL: riceburner700 thats fake. to make that much power up that high the ports would have to be custom and perfect along with some serious custom work with tripple valve springs. sounds just like an f1 dub over |
i believe you need neumatic (sp?) pistons for that....not real
ORIGINAL: mybrokenblinker i believe you need neumatic (sp?) pistons for that....not real Oh and by the way, that's absolutely fake. There's no way an engine set up for road use would be able to turn that fast, there aren't materials strong enough to hold back a piston with the strokeof a road engine that's turning that fast. |
fake..sounded like a jet though
ORIGINAL: amg6975 ORIGINAL: mybrokenblinker i believe you need neumatic (sp?) pistons for that....not real Oh and by the way, that's absolutely fake. There's no way an engine set up for road use would be able to turn that fast, there aren't materials strong enough to hold back a piston with the strokeof a road engine that's turning that fast. they do it on formula one cars. It has to do with the fact that the valve that opens and closes to let in fuel and air has a spring that pushes it into contact with the cam. At that high RPM's, the spring cannot push it fast enough to keep the valve in contact with the cam. Let me know if you have any other questions, cuz im not sure if i explained that clearly enough. |
that phenomina ia called Valve float it is a bad thing but a self correcting problem both valves stay open thus not allowing proper combustion then the rpms drop thus correcting the problem think revlimiter that can never be adjusted(with stock parts) now a rotary and 2 stroke are not limited by this phenomina and are only limited by the streingh of the moving components in the engine
Lol where did that come from |
| All times are GMT -8. The time now is 05:19 AM. |
