cali has some sooper strict emmissions requirements and the refs are getting so good that they can spot JDM swaps pretty fast.
JDM engines typically have slightly higher compression compared to their USDM counterparts. this may be part of the reason why some JDM swaps fail ref tests alot.
I read that the JDM ECU may also play a part. whatever, the reason, check with your local emmissions laws to see whats legal and whats not.
most states require engine swaps to be the same year as the car its going in OR NEWER. not older.
that means if you have an 98, then you should have a 98 JDM/USDM engine swap or newer.
this is part of the reason there isn't much support for b-series swaps in newer EKs. you either get custom engine mounts and try to evade emissions testing or just buy a newer engine, such as the backwards-rotating k20s.
