Go Back   HondaCivicForum.com > Your Ride > Engine & Internal > Swap Meet > ED-EF Swaps
Reply
Old 01-26-2007, 06:41 PM
Powermidget Powermidget is offline
Send a message via AIM to Powermidget
Default OBD0 to OBD1 Conversion
Does anyone have or know the location of a walk through on a obd0 to obd1 conversion...i have a 93 ls motor in a 91 civic hatch...it doesnt have to be specific to that but if it is all the better...thanks
__________________
86 Bronco XLT ~ Blown Tranny&Motor(Ebay'd to Texas)
91 CRX Si ~ Totaled
90 CRX Dx(b16) ~ Jacked
96 LS Teg ~ Traded
91 HB B18a1~Blown Trans FOR SALE
93 Miata MX-5 56000 orig miles SWEET!!!
Sponsored Links
Old 02-16-2007, 10:33 PM
finalimpact finalimpact is offline
Send a message via AIM to finalimpact Send a message via Yahoo to finalimpact
Default RE: OBD0 to OBD1 Conversion
well this is rather late.im not sure how i overlooked yoru post. but when you buy the obd0-obd1 conversion harness they come with instructions on how to wire up the o2 sensor and any extra sensors needed. what exactly are you needing to know? and dont do what i did and make your own harness..........it was a big PITA
__________________
Old 02-17-2007, 01:00 PM
I just didnt want to get it and not be able to put it in or have to buy any extra stuff so i was looking for possible problems i would run into i guess
__________________
91 CRX Si ~ Totaled
96 LS Teg ~ Traded
Old 02-18-2007, 11:08 AM
its pretty straight foward of an install with the directions sitting in front of you. it usually takes less than 30 min to do assuming you have the necessary parts installed on the engine already like distributor, 4 wire o2, knock sensor if applicable.
__________________
Old 02-20-2007, 12:57 PM
okay well i have a b18a1 (obd1)and i didnt do the swap but i can see the grey plug hanging for the distributor...this motor comes with a 4 wire 02 sensor right? so it should all be there shouldnt it? if not what do you think i would need or where should i start looking to figure it out?
thanks
__________________
91 CRX Si ~ Totaled
96 LS Teg ~ Traded
Old 02-22-2007, 01:17 AM
can you get a pic of the under hood? and do you know what ecu your running?
__________________
Old 02-22-2007, 11:59 AM
ill check to see what ecu im running and ill get an engine bay pic up later today
__________________
91 CRX Si ~ Totaled
96 LS Teg ~ Traded
Old 02-25-2007, 12:30 PM
">This is the engine bay and the two plugs that have no connection (throttle body and distributor)
__________________
91 CRX Si ~ Totaled
96 LS Teg ~ Traded
Old 02-25-2007, 11:24 PM
the un[lugged plug in the tb pic is for a purge solenoid...dont worry about that, it wont throw a code or hurt you. it looks to me that the engine is running obd1. it also looks that your second empty connector should be for your o2 sensor(1 wire)...........
__________________
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
