95 motor into a 96 civic
i have a 96 civic ex and my motor locked up. my buddy has a 95 honda civic ex which is totaled.will the 95 engine bolt up to my 96. if so what all complications could i run into. also is the transmissions and axels the same. by the way my 96 is a d16ya and im not sure what the 95 engine is but i know its stock sohc 1.6. PLEASE HELP. i really need to get my car back on the road. thanx
RE: 95 motor into a 96 civic
sorry that was a d16y8 on the 96 ex
I'm doing the same swap right now, The 95 motor is a d16z6, found a difference in the distributor on how it mounts. and I think I need a different ECU. Can not get car to run yet. Not sure, but I believe the injector timing is different.
I believe 96 is OBD2, while 95 is OBD1, so distributor, ecu andwiring changes are in order.
Willthe OBD1 ECU work with a OBD2A to a OBD1 jumper harness in the 96 civic? And will the 95 distributor work, or can I use the96 distributor with mods?
I'm not doing swaps, I just told you all what I could on the subject, wait for a person with experience withswaps to answer...
| All times are GMT -8. The time now is 04:10 AM. |
