I think I have found the best example of why the Gene Pool needs some chlorine. The car is up on jackstands. What the hell is the point? Also as one of the comments points out, the temp gauge is at dead cold.
"This is my video, my car and I assure you, nothing is wrong, everything is legit. Wiring, sensors, everything. While I was doing a GS-R brake swap I had the car in the air with the engine on and in gear letting the tires freespin so I could check for binding. My friend and I thought it would be funny to use this opportunity to do an in-garage Top Speed Run. This is the result, in a b16 with 4.400 LSD gears, I reached 142mph@8300rpm. Enjoy"
I wish the jackstands would have collapsed while he had it going "142".
__________________
Quote:
ORIGINAL: kokasian
to hell with her boots, you should totally have sex with her!
