Check engine light??
Old Jun 8, 2004 | 11:17 PM
OrangeCivic's Avatar
Default Check engine light??
I have a 93 civic cx and just put a 4-2-1 header on it and now my check enging light comes on after about 5 to 10 min.
I still have the stock oxygen sensor and catalytic converter on as well. There is also a cat back system already installed prior to the header. Any ideas on how to fix this problem??
Old Jun 8, 2004 | 11:56 PM
polo708's Avatar
Default RE: Check engine light??
its most likely something with the O2 sensor... give it a wiggle or unhook it and try hooking it up again.
Old Jun 9, 2004 | 12:03 AM
So you figure its jsut a bad connection? I will give it a try thanx. I have had ppl tell me having the cat on will mess my oxygen sensor readings up, ever heard of that? I also have a cool air intake but that went on after, dunno if that would make a difference?
Old Jun 9, 2004 | 02:38 AM
NTX's Avatar
NTX
Disconnect the battery for a minute, then see if it still happens.
Old Jun 9, 2004 | 08:43 AM
green98lxsedan's Avatar
might be time to repace them anyway
not having the cat on might trip the light, but having one wont
Old Jun 9, 2004 | 12:55 PM
polo708's Avatar
you could also do what NTX said... but when they are disconnected touch the leads together (away from the battery of course) then reconnect to the battery and let the car idle for about 10-15 minutes. It will reset the computer in your car and force it to relearn everything it knows.
Old Jun 9, 2004 | 04:58 PM
Hey I reset the comp and now it ran good for the 15 min idle time then I took a little ride and still fine. But when I was on my way out to my gf's it came on again?[sm=smiley5.gif]
Old Jun 10, 2004 | 01:16 AM
polo708's Avatar
sorry man... Im outta ideas now?
Old Jun 10, 2004 | 04:20 AM
NTX's Avatar
NTX
Have a local shop possibly check for error codes. Some places check it for free....i think.......
Old Jun 10, 2004 | 10:03 AM
Ok thanx for the help anyways it was worth a try.
