We're adding and testing new features:  Create your Garage, used it? Give us some feedback here.
Go Back   HondaCivicForum.com > Your Ride > Engine & Internal > Swap Meet > ED-EF Swaps
Reply
Old 01-30-2007, 08:13 PM
civtec00 civtec00 is offline
My Garage
Default b16a1 parts info
i will be getting a 1990 civic hatchback dx, pretty soon. and i will eventually get a b16a1 from a jdm sir from online, i heard that the b16a1 uses the same parts(water pump, timing belt, clutch, etc.)as the b16a3, found in a 1994-1995delsol. is this true? thanks.
__________________
1969 chevelle 350 4 speed
1990 civic hatchback dx b18b 5 speed
1990 civic hatchback dx d15b2 turbo 4 speed
1989 civic hatchback si 5 speed
Sponsored Links
Old 01-31-2007, 01:01 PM
Powermidget Powermidget is offline
My Garage
Send a message via AIM to Powermidget
Default RE: b16a1 parts info
The clutch on the del sol was hydro and the a1 (gen 1) is a cable clutch so that is not the same....the timing belt is prob the same and i really dont know about the water pump
__________________
86 Bronco XLT ~ Blown Tranny&Motor(Ebay'd to Texas)
91 CRX Si ~ Totaled
90 CRX Dx(b16) ~ Jacked
96 LS Teg ~ Traded
91 HB B18a1~Blown Trans FOR SALE
93 Miata MX-5 56000 orig miles SWEET!!!
Old 01-31-2007, 07:43 PM
My Garage
so then i should look into a clutch for a 90-93 integra then, right?
__________________
Old 02-01-2007, 12:41 PM
My Garage
Just get a bseries act stage 1 clutch you just have to make sure it says for cable trans...
__________________
91 CRX Si ~ Totaled
96 LS Teg ~ Traded
Old 02-01-2007, 02:50 PM
finalimpact finalimpact is offline
My Garage
Send a message via AIM to finalimpact Send a message via Yahoo to finalimpact
keep in mind.........the 90-91 cable transmissions use a different spline count for the clutch disc in comparison to the 92-93 transmission. you need to find out what year the engine and transmission is your getting.
__________________
Old 02-01-2007, 09:06 PM
My Garage
it it on one of the websites for jdm motors. it says it came out of a jdm89-91 civic/crx sir.
__________________
Old 02-02-2007, 01:05 AM
My Garage
assuming they send you nothing but an 88-91 engien and tranny combo...the 90-91 integra ls clutch is what youll need.
__________________
Old 02-09-2007, 09:13 PM
My Garage
i heard that i should get a clutch for a 92-93 integra gsr with the b17, because it is really the same motor, internally, and externally as the b16a1, and the clutch for the b17 is the same from as a 94 delsol b16.
__________________
Old 02-09-2007, 10:35 PM
ic892003 ic892003 is offline
My Garage
since ur buying the engine online, alot of the swaps include the jdm clutch, just use that one
__________________
Old 02-10-2007, 05:16 PM
My Garage
im not going to put a used clutch in a car, and than have to put another in. i want to put a stage 1 clutch in the car anyway
__________________
Reply
Tags
1990, 90, b16a1, b18, belt, cable, civic, clutch, engine, hatchback, hb, honda, hydro, jdm, parts, si, stage, timing, trans
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
