Go Back   HondaCivicForum.com > Your Ride > Engine & Internal
Reply
Old 02-06-2007, 03:51 PM
WTB9295Hatch WTB9295Hatch is offline
Send a message via AIM to WTB9295Hatch
Default B18A1 Build Up
Okay so now that I have decided on the 92-93 B18A1 motor I need some more help. What all do I need to do to the block to reach my goal of 400 fwhp? I know I'll have to sleeve it but I want to stay at the stock bore. Can I bore it to say .030 and then resleve it to stock bore? What else willI need to do to hold that kind of cylinder pressures?
Sponsored Links
Old 02-06-2007, 04:31 PM
kimsuprapa kimsuprapa is offline
Default RE: B18A1 Build Up
Somebody correct me if I'm wrong, but I don't think you need to sleeve for 400hp. I believed it to be necessary when upwards of 550hp.
Old 02-06-2007, 05:29 PM
Still better to be safe than sorry. But if that's true then I don't have to do anything else correct?
Old 02-06-2007, 05:40 PM
Powermidget Powermidget is offline
Send a message via AIM to Powermidget
Get some low compression pistons with new rodsand new valvetrain...like dual valvesprings and some titanium retainers...andsome forced induction cams
__________________
86 Bronco XLT ~ Blown Tranny&Motor(Ebay'd to Texas)
91 CRX Si ~ Totaled
90 CRX Dx(b16) ~ Jacked
96 LS Teg ~ Traded
91 HB B18a1~Blown Trans FOR SALE
93 Miata MX-5 56000 orig miles SWEET!!!
Old 02-06-2007, 05:55 PM
I'm planning on doing all that but I need to build the block first to be able to hold that kind of cylinder pressure.
Old 02-06-2007, 07:23 PM
I understand you feel the need to reinforce your cylinder walls, but do a little more research. You may be able to save urself the extra 6-800 bux on something more necessary. Not tryna come off as an *ss, just would hate for u to waste ur time + $. I know a guy locally who's running ~440whp with just the list powermidget gave + a good tune. Here are a bunch of examples of big power out here in PA from a local shop called Evans Tuning: http://forums.evans-tuning.com/index...c5af56d4347c9e
I'm sure those guys can give u another perspective rather than just mine. Hope this helps.
Old 02-06-2007, 07:58 PM
Not tryin to be anal here but money really isn't a concern on this build. Would it not be better safe than sorry? I mean it's not going to HURT the block being sleeved, I just want other options on top of sleeving the block to fortify it. I mean can I do anything else to make it stronger?
Old 02-06-2007, 09:17 PM
In that case I'd say sleeving is ur best bet. Forged rods, new piston rings, and maybe a double or triple-layer headgasket. Add that to powermidget's list and u should be set.
Old 02-06-2007, 09:59 PM
Kedawei Kedawei is offline
FI cams blow. ITR/CTR cams ftw.
Old 02-08-2007, 05:19 PM
I'm no where close to buying cams yet...bottom end first then top end. But when I do more than likly they will be Comp Cams.
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
