RE: What should I put in a CRX!
ZC arent as reliable as other motors....it really depends on how much money you are willing to spend,weather or not they are mpfi,and how much work your going to do yourself...
B18A1(140hp) is a cheap swap (tons of torque)that would be good for boost in the future (10psi on stock block)
B16a(160hp) is a little more expensive(less torque more power)...if you get it with an lsd you car will be a rocket (i had one) (good for na or boost)
B18c1(170hp) is the next step up...good torque and vtec...best for a na set up (requires an extra tranny mount for hydro)
or you can do a mini me swap and give yourself vtec...this is cheapestbut has the least powergains
__________________
86 Bronco XLT ~ Blown Tranny&Motor(Ebay'd to Texas)
91 CRX Si ~ Totaled
90 CRX Dx(b16) ~ Jacked
96 LS Teg ~ Traded
91 HB B18a1~Blown Trans FOR SALE
93 Miata MX-5 56000 orig miles SWEET!!!
