Go Back   HondaCivicForum.com > Your Ride > Engine & Internal
Reply
Old 02-14-2007, 02:01 PM
Civman89 Civman89 is offline
My Garage
Send a message via AIM to Civman89
Default D16y7
Ok i have a D16y7 sohc (about 106 stock)there is alot of talk about people doing swaps and boosting and just boosting their d-series engines...I was wondering if it would be better for me to either stick with the d16y7 and boost it, or for me to do a swap like a b16 or b18 and thenboost??
Sponsored Links
Old 02-14-2007, 06:24 PM
CivicSi45 CivicSi45 is offline
My Garage
Default RE: D16y7
you can boost it but i had a friend boost his and it blew when tuning it. He got it fixed and it goes fine now.
Either swapping or boosting will both give you what you want. But if i was you go with the b18c
Old 02-14-2007, 07:25 PM
Marty's Avatar
Marty Marty is offline
My Garage
Send a message via AIM to Marty
Default RE: D16y7
I boosted a Y7 for a good while, it did blow but because I was at the track and upped my boost to 18psi butdid not put my 18psi tune on my ecu. It's a ok engine but I suggest a Y8 intake manifold and a 96-00 ex transmission for starters
__________________
1989 Mustang LX Notch 5.0 5 speed SSP(Utah State Police car) 1 of 776 Made Nation Wide
Old 02-14-2007, 10:18 PM
Kedawei Kedawei is offline
My Garage
Default RE: D16y7
^ What Marty said.
D series are no more suseptable to "blowing" than any other motor. Most people will tell you to mini me, but your head is fine with a port. The only head worth using unported is a Z6.
Old 02-14-2007, 11:13 PM
Nail I3unny Nail I3unny is offline
My Garage
Send a message via AIM to Nail I3unny
Default RE: D16y7
first mod should be a 96-00 ex transmission, then intake manifold and intake.
Old 06-19-2008, 05:13 AM
kennmonster kennmonster is offline
My Garage
Default RE: D16y7
BUMP
Will an intake manifold from a Y8 bolt up to my Y7 Head. I don't want to do the Mini swap, I would prefer to just do the intake manifold and work from there. What do I do for a throttle cable?
__________________
Kenn
1999 Honda Civic EX 4DR
I drive a manual tranny b/c my girlfirend can't.
Old 06-19-2008, 11:35 AM
trustdestruction trustdestruction is offline
HCF Sol'er
My Garage
Send a message via AIM to trustdestruction
Default RE: D16y7
Quote:
ORIGINAL: kennmonster
BUMP
yes
a mini-me swap can be quite rewarding... bolt-on 25hp.
Old 06-20-2008, 05:09 AM
My Garage
Default RE: D16y7
Quote:
ORIGINAL: trustdestruction
BUMP
yes
I have decided to do the mini me. I am going to start collecting parts for the build. I have found stock intake manifolds but what do I do about the sensors. I found a complete wiring harness for a d16y8 from a 99 ex manual, would this solve the sensor connector problem, I would prefer not to cut wires to make it fit.
__________________
Kenn
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
