component speaker question
Old Feb 17, 2007 | 09:24 PM
drbyers's Avatar
Default RE: component speaker question
here's the actual crossover:
Im also looking at the directions that came with the speakers (which are lousy directions, i might add) and they leave the 7th tab blank.
i guess its just an infinity thing. lol.
btw, the directions automatically assume that the buyer will have an aftermarket amp. great...
Old Feb 17, 2007 | 09:37 PM
Stumasters's Avatar
I don't know what the hell that 7th tab is for, lol.
I looked it up, it says -3db, all that tells me is that slot provides some sort of outboard signal thats high pass crossover filtered somehow.
I would just stick with the first 6, and hook it up like i mentioned, and forget that tab exists. If and when you get an amp, just run RCA wires to your amp from your head unit, and run new thicker speaker wires back to the door through the car cabin, wire them up to the inputs, and leave your other connections alone.
Hope that helps, lol.
I was like, 7th tab, WTF...
Old Feb 17, 2007 | 09:47 PM
drbyers's Avatar
thanx for the advice.
Old Feb 17, 2007 | 09:50 PM
Stumasters's Avatar
Anytime, glad I could figure it out, lol. Drinking and car stereo are never a great mix for me.
Old Feb 17, 2007 | 09:57 PM
drbyers's Avatar
Hey Stu, I think i may have figured it out.
let me do a diagram real quick based on my Acura wiring schematic diagrams.
Old Feb 17, 2007 | 10:22 PM
drbyers's Avatar
hows this, stu?
Old Feb 17, 2007 | 10:30 PM
Stumasters's Avatar
Looks pretty good. And later if you add an amp, just run wiring from the amp directly into the doors, and just terminate your factory /head unit power leads in the door, and replace them with the amped inputs from the trunk.
You should still get decent sound with your set-up there, but you might notice some distortion, if so, I wouldn't blast them to the max until you get an amp.
Old Feb 17, 2007 | 10:31 PM
drbyers's Avatar
i'm deeef already. i won't be blasting anything. lol.
thanx again.
Old Feb 18, 2007 | 02:06 AM
blackmetal619's Avatar
did you figure it out drbyers? i have the 6.5' components, the infinity reference 6010...maybe i could help if you had any questions
Old Feb 18, 2007 | 08:38 PM
drbyers's Avatar
i thought i figured it out and then this happened:
I was going to splice the woofer wire and run the new wiring to the crossover like i was instructed, but then i realized that the woofer adapter wiring had FOUR wires, not the normal TWO.
two blue/green positives and two gray/black negatives like in this picture:
Is this some kind of inline component wiring scheme?
because the guy i used a tutorial from only spliced TWO wires from the woofer component area:
hey stu, i'm stumped!
here's the original DIY tutorial i accessed from team integra. jeezis. this is turning into brain surgery...
http://www.team-integra.net/sections...?ArticleID=868
