Honda Civic Forum   Classifieds   Photo Gallery   Member List   Calendars   Search   Contact Us   Sponsors
  Honda Civic News   Forum FAQ   Timeslips   Civic History   Recalls   TSBs   Register   Login
Looking to turbo a 01-05 D17 Civic? Look here.
  Printable Version
Honda Civic Forums >> Your Ride >> Nitrous, Super Chargers, & Turbos >> Looking to turbo a 01-05 D17 Civic? Look here. Page: [1] 2   next >   >>
Login
Message << Older Topic   Newer Topic >>
Looking to turbo a 01-05 D17 Civic? Look here. - 2/20/2007 5:37:50 PM
SovXietday
Status: offline
SovXietday's photo gallery
This post is for those of you that want to turbo your 01-05 EX/DX/LX Civic equipped with a D17. Unfortunately the D17 is the engine with the least amount of aftermarket support. It is also not backwards compatible with the previous gen D16 and D15 powerplants. This poses for many problems, most of which I will address here and some of which I have limited knowledge about. So, please read and take into account what you want, how much money you want to spend, and how much time your willing to throw into researching and understanding how everything works.
First and foremost, before you even start looking at turbo kits, you need to know what you have available for tuning fuel and ignition as ultimately that will be what is most important in the entire setup. Since FMUs will ultimately blow your engine, it's not worth even mentioning. If you plan on using one, go slam your head in a door. It will be more productive, and it may teach you something... that you're an idiot. Mmkay?
Your two other choices, one which will "do" and the other which will work great, are as follows. ECU piggyback system and ECU stand alone.
Unlike the previous gen D16 options, you cannot revert back to OBD1 and chip the ECU. It doesn't work, so basically that eliminates Uberdata, Crome, Hondata, Neptune, and any other chip or program that runs off the OBD1 ECU. Your cheapest option would be using some form of Piggy back system, IE Greddy Emanage, the SAFC/VAFC, or similar products. Most of these products are ok, they will work for mild setups but may have trouble idling larger injectors and they really don't do well with timing control. IMO, not having good timing control will cause premature engine failure quickly. Your best bet is going to be going with a standalone.
A standalone unit completely replaces the ECU in the car, and takes full control. AEM EMS is a perfect example, and better yet, it has FULL timing control. Timing needs to be retarded with boost and you can maximize the power that you make by playing with timing. It will also control fuel input, so not only will you have enough fuel during full throttle boost, but you'll have good fuel when you're just cruising around town. Best option, but also expensive option. Honestly, there is no expense too great for tuning, the better your tune, the more power you will make, and the longer your car will last.
Next, you will need to either find a company that makes a good solid turbo kit, or decide to piece together one yourself. Do NOT buy the Ebay kits, yes they are cheap, yes they suck, and if you need to be resorting to an ebay kit then start considering what you really have money to do. Tight budget
+ turbo = problem.
As for a turbo kit, look around. I've heard Apexi made one, but I'm not sure if they still do or not. As for building your own, you will need to have a custom turbo manifold made, as there are no companies (that I'm aware of) that mass produce these manifolds. Piping, downpipes, etc are also almost always going to be custom anyway. You will need larger injectors, and probably a new fuel pump. I'm not sure off hand if you can get a Walbro intank for those cars, but any inline can be set up correctly. Oil lines will need to be run just like always.
After all of that, you're still stuck on a stock engine. It's debatable how much these engines can handle before blowing, I'd say that with a stand alone unit you could push around 200whp before running into any issues.
So, now you know what needs to be done for an 01-05 Civic. They will cost a lot more to turbo correctly than the previous gen counterparts, so take this into account before you try and blow up your engine.
Edit:
Here's a post written by one of our members who put together a D17 and made over 400whp.
http://www.hondacivicforum.com/m_456149/tm.htm
< Message edited by SovXietday -- 8/26/2007 9:18:42 AM >
_____________________________
Champ White 1996 Civic Hatchback - 57trim SOHC
Black 1998 Z28 Camaro - LS1 M6
Post #: 1
RE: Looking to turbo a 01-05 D17 Civic? Look here. - 2/20/2007 5:39:27 PM
INJENalltheway
Status: offline
Woo woo!  Thank you Sov!
IF ANYONE IS INTERESTED IN A D15B7 HEAD LET ME KNOW. I CAN REBUILD MINE FOR YOU.
Yeah That's Right Rabbit!!!
(in reply to SovXietday)
Post #: 2
RE: Looking to turbo a 01-05 D17 Civic? Look here. - 2/20/2007 6:23:04 PM
mxs
Status: offline
mxs's photo gallery
Thank you for posting this
Driving takes 3 abilities: Accelerating+braking+turning. More power only helps acceleration. Lower weight helps all 3.
DON'T EMAIL ME W/ TECH QUESTIONS, I WILL IGNORE YOU.
(in reply to INJENalltheway)
Post #: 3
RE: Looking to turbo a 01-05 D17 Civic? Look here. - 2/20/2007 8:30:51 PM
Belmont
Status: offline
Belmont's photo gallery
quote:
ORIGINAL: SovXietday
Dezod.com has complete turbo kits, everything you'll need to turbo the d17.
And its hard to say what the d17 can handle, a lot of factors come into play... Stock enternals, id say your looking at about 180 whp without problems.
Great post Sov, hopefully people will look at this before posting noobish questions about boosting 7thgens.  for you.
Post #: 4
RE: Looking to turbo a 01-05 D17 Civic? Look here. - 2/20/2007 10:00:51 PM
bakertime
Status: offline
bakertime's photo gallery
Thanks man, it's good to have all that in one place for reference!  I doubt I'll ever be pursuing it, but  you never know...
:D
< Message edited by bakertime -- 2/20/2007 10:01:19 PM >
2001 Civic EX 5 Spd - FS: http://www.hondacivicforum.com/m_535013/tm.htm
(in reply to Belmont)
Post #: 5
RE: Looking to turbo a 01-05 D17 Civic? Look here. - 2/20/2007 11:00:29 PM
Kedawei
Status: offline
I would add my comments posted in a few threads down, but I don't wanna ruin your thread here Sov.
(in reply to bakertime)
Post #: 6
RE: Looking to turbo a 01-05 D17 Civic? Look here. - 2/20/2007 11:14:59 PM
SovXietday
Status: offline
Post them up and I'll add them to my post.
(in reply to Kedawei)
Post #: 7
RE: Looking to turbo a 01-05 D17 Civic? Look here. - 2/21/2007 10:59:56 AM
Remmy
Status: offline
Remmy's photo gallery
Stickied
Post #: 8
RE: Looking to turbo a 01-05 D17 Civic? Look here. - 2/21/2007 6:10:43 PM
Kedawei
Status: offline
Well here was my post. I sound a bit rash in it, but its just my way of being honest.
"As for the D17, the main, blaring problem that I see with it is its stroke. Its long stroke creates several problems: increased cylinder wear, increased piston speed which increases stress/wear throughout the bottom end (the wrist pin location is actually offset to cope with this, that's a bad sign), and poor top end power. In addition to that, if I recall, it has a returnless fuel system, which means fuel pressure cannot be increased, and older metal intake manifolds cannot be used to directly replace the plastic manifold that's in there now. It also has a distributorless ignition, so I don't know how you would adjust ignition timing without the use of AEMs full standalone unit ($1500) or equivalent, which is fine I guess since tuning fuel with piggybacks is crap anyway, and you can't use older ECUs with the traditional Neptune, Hondata, Chrome, etc. I'm also not sure who makes an aftermarket cam or valvetrain assembly for it, which I guess is ok because you wouldn't want to rev it that high anyway.
Basically its expensive, its labor intensive, and when you're all done it still won't work as well as the older D series. "
(in reply to Remmy)
Post #: 9
RE: Looking to turbo a 01-05 D17 Civic? Look here. - 2/21/2007 7:54:00 PM
01CivicEX
Status: offline
01CivicEX's photo gallery
TSI also makes D17 turbo kits. Crower makes cams, valves, and valve springs, and someone just released a bigger throttle body if you wanna go NA. As for how much the engine can handle, I know several peopel w/ decent turboed 7th gens with no problems at all.
Post #: 10
Login OR Register now to post a reply to this forum topic.
Jump to:
Featured Sponsors
Go
Advertising Info
Top 10 Posters
forty0414155
remmy11161
fiirkan10321
mill$civic8433
marty8262
mxs8005
nail i3unny7705
sacicons7674
fliphkd7207589
pete7169
New Vendors
K&N Engineering, Inc.
