i have a d15b7 sohc non vtec engine, instead of doing a full swap i was thinking what is a good head swap i should do??? i was thinking maybe ls or b16 maybe???, what else is needed in a head swap i know its easy since u dont have to change the tranny or axles...... but what else ecu??
Get everything from the top of the block up, and the ECU. Do a search for mini me for a specific list of parts. Internals would be a good idea for anything over 200hp or 8000rpm. Your internals choices are limited to Crower, or custom rods from another manufacturer, and plenty of OEM or aftermarket piston options.
yea i know that, at least now i do lol, wow thanks for the thread gsr, maye i should tryo to do this nmyself, do i have 2 get the ecu for the z6 or can i use the ecu thats currently in my car?
you will have to use the exu from the z6 as this ecu has the data on it to control the VTEC
unless the ecu that is already in your car is a VTEC ecu. . . from what im lead to believe anyways ahaha
__________________
Not everyone wants a swap or to go turbo....
**** YO MOMMA* ****** *** ****
(To see the hidden text press ALT+F4)
