Go Back   HondaCivicForum.com > Your Ride > Detailing
Reply
Old 02-22-2007, 06:54 PM
Chaos Chaos is offline
My Garage
Default Interior Redesign
I am planning on painting all the vinyls in my interior midnight black instead of that dark grey colour. Is there any special way to do it or is it just vinyl paint on vinyl, dry and reinstall. Im also going to replace the ?trim? (that piece of carpet in the centre of the door above the arm rest, under the handle) with a red fabric with a black tribal pattern down the length of it. How do I remove and replace that bad boy? Black and red bucket seats. And my roof and floor carpet is going to get replaced with black carpet (suprise, suprise) with a white tribal patern down it with UV lightsilluminatingit. This is just a case of taking the guts out of the car and replacing it all I assume. Anyone got any advice? Is it possable to do a DIY on it or is it a bit too much? How do you think that will look?
__________________
Ride together, Die together.
-Tears shed in training saves blood shed in the battlefield-
Sponsored Links
Old 02-22-2007, 07:04 PM
ryank327 ryank327 is offline
My Garage
Default RE: Interior Redesign
Fabric on door DIY http://www.honda-tech.com/zerothread?id=1182294
Painting Vinyl Pieces http://www.hondacivicforum.com/m_235420/tm.htm
As for the carpet, you can buy it at home depot or lowes. I find that pool deck carpeting looks and works the best. Just cut it to fit, which is a pain, and use spray adhesive to attach it.
__________________
IMMA EAT YOU
Old 02-23-2007, 08:57 AM
My Garage
Thanks for that. However I am not to keen on loosing the texture of the stock dash. So I am considering skipping the sanding steps. Or is it unavoidable that you loose the texture so I should sand it anyway?
__________________
Old 02-23-2007, 09:11 AM
My Garage
Then you should just skip the sanding, clean everything wiht rubbing alcohol, paint cleanup(not thinner) or something of the sort to get all the greases and oils off. This is probably the most important part. Any grease or oils left on will cause the paint to peel and chip later on so make sure you do this very thoroughly. After your done witht hat rinse/wipe everything off with water and let it dry. The two brands of paint Id reccomend would be duplicolor or krylon. Do a couple coats of primer, being sure to let them dry. Then do several coats of your color and if desired a coat or two of clear. I did this on all the vinyl in my old hact. Everything turned out great but the door panels which peeled after a few months. Im guessing since they have the most contact there were more oils on them then I suspected. I used a can of plastic primer I bought at lowes, regular duplicolor filler primer and krylon plastic paint from walmart.
__________________
IMMA EAT YOU
Old 03-17-2007, 12:16 AM
Carlz0r Carlz0r is offline
My Garage
Use vinyl dye instead of paint. It soaks in if I remember correctly, which should allow you to keep most of the texture.
__________________
Old 03-17-2007, 11:50 PM
MergeThis! MergeThis! is offline
My Garage
http://www.stockinteriors.com/?gclid...FRI_UQodvxkkGg
this is where i'm getting my carpet. they have all kinds of colors and textures... from stock grey, it neon orange. and its molded just like stock... perfect replacement.
__________________
1995 Civic DX
Old 03-18-2007, 08:48 AM
natecivic92 natecivic92 is offline
My Garage
Send a message via Yahoo to natecivic92
Good thread have you got it complete yet if so can we see some pics.I want to do the same thing but in glossy black
__________________
Old 03-18-2007, 09:15 AM
absoulute absoulute is offline
My Garage
get scotch brite pads and scuff stuff and this will keep the texture and get the oils out. vinyl dye for a spray gun is more expensive then jus regular paint might hold up a lil better then jus base/clear paint..
__________________
19 inchs and 10 switchs........
Old 03-18-2007, 05:12 PM
Dustin Dustin is offline
My Garage
don't do it the ghetto spray paint way. buy some of the vinyl dye, and do it right. i'm sick of people sanding their dashes smooth, and complaining about glare.
Old 03-18-2007, 11:25 PM
reaper2022 reaper2022 is offline
Window Lickin' Moderator
My Garage
Quote:
ORIGINAL: Dustin
The ghetto spray paint way actually works if you do it right
__________________
Mustang Build Budget:
---I---------- <-- It's going up
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
