Moogly's Make-Over
Old Mar 13, 2007 | 01:39 AM
  #21
TheMoogly's Avatar
Default RE: Moogly's Make-Over
Before
After
To paint my valve cover I used semi-flat KRYLON enamel spray paint... to do my HONDA I used TESTORS brand Gloss Gray Gris Brilliant 2538 Enamel Paint Marker that I bought from a hobby shop... IT IS FANTASTIC! Since the valve cover heats up it actually smoothed out the paint and made it look very factory made... I made sure I used a fine grit sandpaper to rub it down and rub the enamel off the letters before i painted them!
Old Mar 13, 2007 | 03:08 AM
  #22
patto_001's Avatar
whats next for it ?
Old Mar 13, 2007 | 11:47 AM
  #23
TheMoogly's Avatar
I am test fitting a header for WestImports along with a high flow cat that Khanselman is sending me and after that I plan on updating my grounding wires (windcalmer, as soon as I get a better shot of my enginebay I will send it!) and that'll be all I can do until I scrap the whole thing and do the k series swap! I'll probably end up doing a k24 because it will be cheaper.
Old Mar 13, 2007 | 12:19 PM
  #24
header and cables should make it look very nice under the hood!
be sure to put up pics
Old Mar 13, 2007 | 12:55 PM
  #25
My04Civic's Avatar
Administrator
hey man, do you think the paint pen you used will get too hot and drip?!
Old Mar 23, 2007 | 11:03 PM
  #26
tknaub's Avatar
Moog, what kind of sandpaper did you use? i use 400 grit for things that just need to be ruffed up a bit, you know PPP (Prep, prime, and paint) is usally your best bet to keeping your paint in one place, and not having to worry about drips.....but thats only boatswain-mate talk....^^
Old Mar 24, 2007 | 11:19 AM
  #27
TheMoogly's Avatar
It has been a couple weeks now and absolutely nothing wrong with the paint... it is smooth and looks like a factory painted it. I used super fine sandpaper... I dont know the grit but it was almost smooth enough to not really scratch unless I applied pressure.
TheMoogly
Apr 29, 2007 11:41 PM
TheMoogly
Apr 27, 2007 02:36 PM
TheMoogly
Apr 3, 2007 07:25 PM
TheMoogly
Mar 21, 2007 11:20 AM
TheMoogly
Mar 9, 2007 01:14 AM
