Go Back   HondaCivicForum.com > Your Ride > Engine & Internal
Reply
Old 01-29-2005, 11:08 PM
solidgroove solidgroove is offline
My Garage
Default New fuel rail 93 civic
I have a 93 Civic and im thinking about upgrading to a "AEM" fuel rail. Will this add any horespower; what are the advantages of a high flow "rail" ?
__________________
Domination Through Amplification
Sponsored Links
Old 01-29-2005, 11:16 PM
sacicons sacicons is offline
My Garage
Default RE: New fuel rail 93 civic
its not going to do much unless your fuel demands are higher than normal. if you are using some form of forced induction or have raised the compression and changed the fuel pressure or maps, then it can help. its not about HP, its about not blowing up your motor from too lean a mixture. its not worth it unless you already have a lot done.
__________________
Quote:
ORIGINAL: Forty04
I choose the rear ending
Old 01-30-2005, 01:05 AM
My Garage
I guess what Im trying to do is add a few more horsepower without going broke. I want this because I would like to have a little more push on the interstate and zero to sixty in hectic traffic.
Thanks for the info!
__________________
Old 01-30-2005, 02:01 AM
My Garage
get an AEM intake. either the cold air, or the V2. then, get a quality (such as Greddy) cat-back exhaust system. injen is another good brand of intake BTW. get a higher quality one, it'll fit better and should see a little more power than a cheaper one.
__________________
Quote:
ORIGINAL: Forty04
Old 01-30-2005, 02:06 AM
My Garage
Thanks again for the info. I've read many of your post and you know your "stuff". I have an "AEM" intake but the exhaust thing is now on my list.
__________________
Old 01-30-2005, 02:31 AM
D16z6's Avatar
D16z6 D16z6 is offline
My Garage
You should also get a dc sport header. Get a 4-2-1 if you want low end power and 4-1 for high end power.
Also i heard you only need fuel rail if your running turbo or supercharge. Someone correct me if im wrong.
__________________
A
Old 01-30-2005, 02:51 AM
My Garage
basically if you increase the fuel demands, so yeah, FI or higher compression and raising the fuel pressure or new injectors.
__________________
Quote:
ORIGINAL: Forty04
Old 02-08-2005, 07:17 PM
riceburner700's Avatar
riceburner700 riceburner700 is offline
My Garage
Send a message via AIM to riceburner700
would you see a difference with lets say
1. aftermarket intake manifold
2. bigger throttle
3. injectors
4. fuel rail
__________________
cylinder head guru!
Non Vtec power
Old 02-08-2005, 08:10 PM
My Garage
get the throttle body and the manifold, but you dont need the injectors yet. save your money for now. youd be better off getting an adjustable cam gear and/or an aftermarket cam.
__________________
Quote:
ORIGINAL: Forty04
Old 02-09-2005, 12:01 AM
My Garage
well wouldnt they help if i am about to get my turbo on the injectors like 450cc or the 550cc
__________________
cylinder head guru!
Non Vtec power
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
