Go Back   HondaCivicForum.com > Your Ride > Audio/Visual Electronics
Reply
Old 01-31-2005, 09:39 AM
winker winker is offline
My Garage
Default Radio replacment 2002 civic se
I am in the process of replacing the orginal and nasty factory fit head unit with my new DAB radio..And what a pain in the arse it has turned out to be..can anyone point me in the direction of a guide or even help me out by telling me how I go about removing it...
so far I have removed the glove box, and can get my hand, tightly up and behind the unit, I have managed to remove the strorage tray below the radio..but as for the radio im stuck...
many thanks in advance... [&:]
__________________
If at first you fail, post a question in the forum. Some poor soul has probably been stuck here before you....
Sponsored Links
Old 01-31-2005, 11:03 AM
tonguetwiztid tonguetwiztid is offline
My Garage
Default RE: Radio replacment 2002 civic se
same here, except for mine is in a 99 ex. how the hell do i get the radio out??? i just need the serial number off it so i can get the security code. i disconnected the battery when i changed my fule filter and now my radio doesnt work. I bought the car used and didnt get the code when i got the car. honda dealer here said i need radio serial number and they will get me the code. i have tried once to get it out with no luck. any help would be useful, thanks!!!
Old 02-01-2005, 11:50 AM
Remmy Remmy is offline
Administrator
My Garage
Im not sure for a 02, I havent worked on one in awhile. But for a 99 I can do by heart. The 02 might be similar. First remove the glove bpx and belly pan (drivers side). Look closely for screws. the glove box has 2 phillips head screws (all the screws do.) Remove those while the box is still clipped in. Now, remove the glove box. Also the belly pan has three screws, and its also clipped in. Your going to have to tug at it a little bit but dont do it furiously. Then remove the bottom console screws (that are now revealed). Dont forget to remove the clip to the power port. Now remove the 2 big screws under the main console in the frame. Now grab a wedge and use a towel so you dont mess up the plastic while you GENTLY tug/ pull the console out (yes a/c controls and all). As soon as you can get your fingers in there remove all the A/C clips and plugs. Now remove the console and set it down in your kitchen or garage on a soft suface (towel). Grab a wiring harness and a new radio and you are set!
__________________
Old 05-20-2007, 04:14 AM
bammers bammers is offline
My Garage
So I do have to remove a load of stuff? The radio wont come out if I manage to get the tray out underneath it?? My partner has a 2001 Executive and wants to a cd changer and new head unit and I promised to sort it. Little did I realise it seems such a huge job!
So, to recap, glove box, facia panel under steering wheel and search for bolts then the whole unit comes out with climate controls and all???
Jeez!!
Old 05-23-2007, 06:58 PM
05reverb 05reverb is offline
My Garage
02, no need to remove glove box, just get the power socket out (the whole plastic piece, then there is 2 bolts to be removed under that, that is holding all your headunit, so once the 2 bolts are gone, you need to push out really hard to pop it out but dont give up, those are the only 2 bolts holding it trust me
__________________
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
