Honda Civic Forum   Classifieds   Photo Gallery   Member List   Calendars   Search   Contact Us   Sponsors
  Honda Civic News   Forum FAQ   Timeslips   Civic History   Recalls   TSBs   Register   Login
small suspension/tire/wheel project
  Printable Version
Honda Civic >> Your Ride >> Suspension, Brakes, Tires & Wheels >> small suspension/tire/wheel project Page: [1] 2 3 4 5   next >   >>
Login
Message << Older Topic   Newer Topic >>
small suspension/tire/wheel project - 3/11/2007 9:50:26 PM
civicexracer
Status: offline
civicexracer's photo gallery
well i've done a lot of research today since i've had nothing to do all day. i've finally decided on all the parts i want to put on to pretty much finish with my car and will be doing so within the next 2 months. did research on prices and such and heres everything i plan on getting:
Wheels/Tires:
-15x7 Bronze Falken Hanabi's(11lbs each)*Purchased/Installed*
-205/50R15 Falken Azenis Rt-615's*Purchased/Installed*
-Work lug nuts*Purchased/Installed*
Performance/Suspension:
-Energy Suspension shifter bushings*Purchased/Installed*
-Hawk HPS brake pads
-Brembo rotors(still researching but will either be blanks or slotted)
-JDM ITR 22mm rear sway bar(includes endlinks and all hardware)
-Beaks SRK subframe brace
-Beaks rear lower tie bar(just a possibility, i already have a rear lower tie bar so the Beaks one would be more for the "bling" factor lol)
-Prothane swaybar bushings
-Blox rear lower control arms*Purchased, should arrive within few days*
Appearence:
-OEM front lip
-EK side skirts
-re-paint calipers red/paint drums black
-JDM Vision amber corner lenses*Purchased, should arrive within few days*
Falken Azenis RT-615's*Purchased/Installed*
Falken Hanabi's*Purchased/Installed*
JDM ITR 22mm rear sway bar kit(pic is missing D-brackets and the kit im getting does not include those LCA's)
Beaks Subframe kit
Blox LCA's*Purchased, should arrive in few days*
Work red lug nuts*Purchased/Installed*
Hawk HPS pads
Brembo slotted rotors
EK side skirts(Jakes car BTW)
JDM Vision amber corners*Purchased, should arrive in few days*
my deadline to have all this stuff on the car is mid May. i'll prolly be picking up the wheels and shifter bushings hopefully this wednesday. ill have the tires mounted/balanced either by the end of this week or early next week. plan on ordering the LCA's this weekend if i sell the 5 spokes i have within the next couple days. everything else will just come as time goes on...
once the time comes for when i get my hands on all the suspension stuff and get to installing it, ill def. try my best to make DIY's for all of that junk. installing: lca's, front sway bar, rear sway bar, and subframe brace...after a couple weeks of having all the products on my car at atleast running at 1 autox, ill make an effort to do a product review aswell.
< Message edited by civicexracer -- 4/9/2007 6:44:51 PM >
_____________________________
proud member of Rubber Duckie Racing -> www.rubberduckieracing.com
Post #: 1
RE: small suspension/tire/wheel project - 3/11/2007 11:25:48 PM
mxs
Status: offline
mxs's photo gallery
quote:
ORIGINAL: civicexracer
Wheels: still have yet to decide but it'll atleast be either 15x7 Rota Slipstreams(12.9lbs) or Rota GT3s(13.5lbs). i like the look and obviously the weight of the slipstream but the 15x7 seem to be a bit hard to find. if i can find them cheaper than $475(the cost of the GT3's shipped) then ill be getting the slips.
I know these aren't on your list but the 15x7 Kosei K1's in silver are on closeout at Tire Rack, $109 each. They're 14 lbs. in that size.
Front Sway Bar: im still researching..i have no idea what kind, how much, where, etc yet tho. hopefully soon enough ill find what im looking for.
what ARE you looking for? if I were you I'd get the rear bar in first and see how the car is responding. see what you really need to change. some people just remove their stock front swaybar, I might try that this year. Here's a bit of info, there's a ton of experience out there, keep searching!
LCA's: was planning on getting Megan Racing LCA's but im prolly gena go with the Blox LCA's. i'll get whichever i find cheaper at the moment of purcashing...found the Blox ones for $110 shipped(i kno MR ones run around the same price).
what are you looking to get out of the LCA's? weight reduction? better bushings? make sure you get something with swaybar holes.
everything else looks good.
Driving takes 3 abilities: Accelerating+braking+turning. More power only helps acceleration. Lower weight helps all 3.
DON'T EMAIL ME W/ TECH QUESTIONS, I WILL IGNORE YOU.
(in reply to civicexracer)
Post #: 2
RE: small suspension/tire/wheel project - 3/11/2007 11:53:49 PM
civicexracer
Status: offline
eh i dont like the K1's much and they weight to much for me...i'll prolly wait after i get the rear sway installed and think more about the front sway. maybe ill like the oversteer lol. as for the LCA's, my OEM ones dont come with holes for endlinks which is my main reason for buying aftermarket ones. the weight reduction is just an added plus i was thinking about getting an Energy bushing kit but figure ill just put that extra $150 or so to an autox school...thanks for the info marnie.
(in reply to mxs)
Post #: 3
RE: small suspension/tire/wheel project - 3/12/2007 12:14:52 AM
mxs
Status: offline
mxs's photo gallery
oversteer is fun
I didn't know your car had no endlink holes in the LCA's. weird.
the poly bushings are a good idea on a car of that age. . . . if you want to deal with the installation.
Post #: 4
RE: small suspension/tire/wheel project - 3/12/2007 5:50:00 PM
civicexracer
Status: offline
ya i think all 5th gens(maybe not the case with the hatch si) dont come with holes for endlinks. i kno it for sure with ej1's tho...the lca's and sway bar come with all the bushings i need brand new so i wont have to bother with buying new ones unless i reall want the energy ones.
(in reply to mxs)
Post #: 5
RE: small suspension/tire/wheel project - 3/12/2007 6:42:37 PM
ej6buddy
Status: offline
ej6buddy's photo gallery
if it doesn't come with factory rear sway bars, then there are no holes for upgrading, sucks, i got the same problem, i just don't want to pay that much just to get lca's with holes.  plus my suspension setup is good enough for me, at least for now
Post #: 6
RE: small suspension/tire/wheel project - 3/12/2007 7:26:17 PM
drbyers
Status: offline
drbyers's photo gallery
hey civicex, it may be me, but i thought the ITR rear sway bar only came in 23 mm???
(in reply to ej6buddy)
Post #: 7
RE: small suspension/tire/wheel project - 3/12/2007 8:02:11 PM
civicexracer
Status: offline
i believe the 99-00 models come with holes in the lca's for a sway bar because the SI come factory with a sway. figure it'd be cheaper to produce just one kind of lca's for those years rather than two different types just for a lil hole..
and there are 22mm and 23mm itr sways. i've seen both on a bunch of different sites. passwordjdm.com used to have both the 22mm but they took it off for some reason, now they just have the 23mm set..
i should be getting the tires sometime this week or next, depending on how soon my friend can get them off his wheels. i've set dates for when to place the order for my wheels, should be either the 23rd or 24th of this month. hopefully ill decide on what wheel/color and find the right seller/price by then. once i place the order for the wheels, ill be putting up my current MB Motoring wheels for sell. i might try to sell em on here, if not their goin on ebay.
(in reply to drbyers)
Post #: 8
RE: small suspension/tire/wheel project - 3/12/2007 8:23:12 PM
ej6buddy
Status: offline
^ honda didn't make them for the 96-98 models because they only put the swaybar package on some of the 99-00 bodystyles
Post #: 9
RE: small suspension/tire/wheel project - 3/13/2007 12:24:30 AM
awsmp5
Status: offline
****ing sweeet
Post #: 10
Login OR Register now to post a reply to this forum topic.
Honda Civic Forum >> Your Ride >> Suspension, Brakes, Tires & Wheels
Jump to:
Featured Sponsors
Go
Advertising Info
Top 10 Posters
forty0414248
remmy11161
fiirkan10517
mill$civic8471
marty8273
mxs8006
fliphkd7207714
nail i3unny7705
sacicons7675
addiction2ba7375
New Vendors
K&N Engineering, Inc.
