manual gear oil
Hey, how much oil will i need to buy to replace the oil in my d16y8's tranny? and honda recomends using reg motor oil right? what weight and i was thinking about using synthetic
RE: manual gear oil
I used regular 10w-30.. need 2-3 quartz.. fill until it start to drip out from fill plug.. (u have a manual.. right ?)
RE: manual gear oil
yes i have a manual
RE: manual gear oil
it's 1.9 quarts, and IMO you should use Honda Genuine Manual Trans Fluid.
RE: manual gear oil
ya use the honda mtf or the gm sycromesh mtf is real good too
RE: manual gear oil
honda doesn't "recommend" putting motor oil in your tranny, it tells you to just use Honda MTF, after it's all said and done, you'll spend the same as you would for any other fluid.
p.s. get about 3 quarts just in case you need extra, as well as a new washer |
RE: manual gear oil
ORIGINAL: ej6buddy honda doesn't "recommend" putting motor oil in your tranny, it tells you to just use Honda MTF, after it's all said and done, you'll spend the same as you would for any other fluid. p.s. get about 3 quarts just in case you need extra, as well as a new washer |
RE: manual gear oil
"HONDA" doesn't recommend conventional motor oil, the retards at your dealership that call themselves honda techniansrecommended you to use regular motor oil, and don't you think it's a little su****ious that they wouldn't sell you their own MTF, imo, that seems a little shady if you ask me. don't always go off of what the honda people tell you, they only know what they hear half the time, at least for all of them near my area.
RE: manual gear oil
I have been using Royal Purple 10W30 in mine for about four months now. It is doing just fine. I would use the Honda stuff, but there is no where to get it anywhere near me.
Is there something in the Honda stuff that makes it better or is there something in the Reg oil that makes it BAD??? |
RE: manual gear oil
I have used regular motor oil in both of my civics and my mechanic has ben using regular motor oil in all civic MTs for many years with no consequences. However you should not use synthetic oil in a tranny. The reason is that the transmission doesn't use a pump to get the oil up in the housing, it depends on oil to kinda "climb" the gears up there and than there's that splash thingie which I don't know the name of. Synthetic oil tends to be thinner for the same weight rating and doesn't "climb" the gears as well.
| All times are GMT -8. The time now is 09:31 PM. |
