RE: Front brakes out of ballance
You can try to unfreeze the caliper yourself (if that is indeed the problem) by prying it open with a big-ass screwdriver. The other thing that could be causing the problem is warped disks (rotors). Get the rotors turned and replace the pads (while you're replacing the brakes, you'll be able to tell if the calipers are ****ed up.) Getting the rotors turned should only cost about $18 or $20 (Not sure how that converts to GBP).
__________________
Your Forum Turbo Groupie...
Also your official Forum EF and GTR Brain-Trust
