Go Back   HondaCivicForum.com > Your Ride > Engine & Internal
Reply
Old 02-06-2005, 02:57 PM
riceburner700's Avatar
riceburner700 riceburner700 is offline
My Garage
Send a message via AIM to riceburner700
Default d-series pulley
what kind of tool do you need to take the pulley off, and were i can get it, or can someone show me how to get it off with like a picture or a website that has directions.
thanks dustin
__________________
cylinder head guru!
Non Vtec power
Sponsored Links
Old 02-06-2005, 04:34 PM
burgo990 burgo990 is offline
My Garage
Default RE: d-series pulley
whats rong with a hammer lmao
Old 02-06-2005, 07:33 PM
Kappa22 Kappa22 is offline
My Garage
Are you talking about the crank pulley?
__________________
Your Forum Turbo Groupie...
Also your official Forum EF and GTR Brain-Trust
Old 02-06-2005, 10:08 PM
My Garage
yeah the crank pulley because when ever i put pressure on it it cranks the engine over so is there some special way like an IMPACT GUN to get it off.
__________________
cylinder head guru!
Non Vtec power
Old 02-06-2005, 10:51 PM
My Garage
DON'T use an impact wrench. There's a couple ways to do it (one of them involves a special tool), but for the easiest one, all you need is a breaker bar. Put the socket/breaker bar on the crank nut, brace it against the frame or the ground or part of the suspension, and crank the engine for AS LITTLE TIME AS YOU POSSIBLY CAN (basically, just turn the key to start really fast and let it off). This will cause the engine's rotation to turn against the breaker bar and break the bolt loose. Make sure you brace the breaker bar the right way. Immediately after this, set the engine to TDC from the cam gear and check the crank mark. Then you will be able to take off the TB or whatever else you're planning to do.
And if you're afraid the car will start, you can always pull the coil wire to make sure it won't.
__________________
Old 02-07-2005, 12:14 AM
My Garage
hmmm sounds simple i will also replace the belt to while i am there, what about torquing the bolt back on how many footpounds
__________________
cylinder head guru!
Non Vtec power
Old 02-11-2005, 08:19 PM
My Garage
got my megan racing blue pulley today looks unbolievable for the price damnnnn
__________________
cylinder head guru!
Non Vtec power
Old 02-11-2005, 08:24 PM
My Garage
What year is your car?
__________________
Old 02-11-2005, 08:37 PM
sacicons sacicons is offline
My Garage
i wouldnt recommend that pulley. sorry, i know this is a little late, but replacing the stock pulley will kill your main bearings and main seal.
__________________
Quote:
ORIGINAL: Forty04
I choose the rear ending
Old 02-11-2005, 08:39 PM
My Garage
There's a damn good reason the stock one is so forkin' heavy...
__________________
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
