Go Back   HondaCivicForum.com > Your Ride > Engine & Internal
Reply
Old 06-15-2004, 08:56 AM
NYC Civic NYC Civic is offline
My Garage
Default Crank Pulley
I know that crank pulley does give a pretty good amount of gain but I remember in the past, someone told it is not a good idea to put a lightweight crank pulley on an engine that's being driven daily. It can do some serious damage to the motor. I forgot why though. Anyone here experience with crank pulley?
__________________
http://www.hondacivicforum.com/m_114406/tm.htm
Sponsored Links
Old 06-15-2004, 11:01 PM
lilol89crx lilol89crx is offline
My Garage
Send a message via AIM to lilol89crx Send a message via Yahoo to lilol89crx
Default RE: Crank Pulley
the 1.6 and larger engines use a harmonic balancer type crank pulley to reduce vibrations. a lightened crank pulley does not have this feature. so in the long run you may end up damaging your engine. now a 1.5 does not use a harmonic balancer, so you could use a light crank pulley but you 1.5 pully is already light weight due to no rubber damper.
__________________
89 crx sold.....91 hatch new project for turbo ls
<br />90 crx dx-daily beater
<br />04 suzuki gsxr750-sunny day beater
<br />83 rx7-pos sittin in the yard
01 yamaha r6 stunt bike-pos that i dont care about
Old 06-17-2004, 05:19 AM
My Garage
I don't quite understand about this. I still don't understand how it would damage your engine. Can you explain it to me more about this? Thanks.
Quote:
ORIGINAL: lilol89crx
__________________
Old 06-17-2004, 09:43 PM
My Garage
a harmonic balancer/damper dampens harmonics which cause vibrations. the 1.6 uses these as the vibrations can cause your #1 main bearing to absorb the vibrations thus causeing bearing damage.
__________________
Old 06-18-2004, 04:47 PM
My Garage
Which other Honda comes with a harmonic balancer? Do you know if the H22A engine also comes with it?
__________________
Old 06-18-2004, 05:45 PM
NTX NTX is offline
My Garage
Most engines made have harmonic balancers.. A lot of the time the pulley and balancer can be seperated.
__________________
Apexi Boost Gauge, Apexi Meter Control Unit, RMR C/F Gauge Pod, Blitz Fatt DC III, Rexpeed Apex VG
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
