Go Back   HondaCivicForum.com > Your Ride > Engine & Internal > Swap Meet > ED-EF Swaps
Reply
Old 03-21-2007, 11:43 AM
89_slammed 89_slammed is offline
Default ...DPFI to MPFI...
ok. Im about to do the fuel injection swap on my d15b. I already have the resistor box from an accord. The question is since the stock pm5 only has 2 injectors am i going to need to get another ecu to run the additional wires for the injectors... it only makes sense. But i wanna make sure so this bitch will run.
Any help is thankful. thanks guys.
__________________
(\__/)
(O.o )
(> < ).... WoRlD dOmInAtIoN.....
Sponsored Links
Old 03-21-2007, 12:41 PM
bakertime bakertime is offline
Default RE: ...DPFI to MPFI...
Whoa dude, triple post?
__________________
Old 03-21-2007, 02:33 PM
Street Sniper Street Sniper is offline
I didn't see the others, but yes, you needthe Si ecu. p06 I believe.
__________________
Tuned by G-Tech... Powered by YooHoo.
Quote:
...there's more than one way to skin the horsepower cat.
Old 03-22-2007, 01:17 AM
finalimpact finalimpact is offline
Send a message via AIM to finalimpact Send a message via Yahoo to finalimpact
si/ex ecu= pm6.......you can also use the 88-89 teggie pg7 ecu and the 90-91 teggie pr4. you will also need a 88-91 crx/civic si,hf,ex distributor, 4 88-91 civic/crx, ex, si injectors, 88-91 crx/civic si,ex intake manifold. since you have the resistor box the rest is labor in wiring.
__________________
Old 04-12-2007, 11:49 AM
markwilson markwilson is offline
Ya you need an ECU. I just did the change and noone told me my DX ECU wouldnt work. 88-91 CRX or SI also I think an 88-89 Acura Integra will work.
Old 04-12-2007, 04:06 PM
skateman190 skateman190 is offline
Send a message via Yahoo to skateman190
so on my dpfi to mpfi with my b16 i can use my b16 ecu right? or do i need another one too? sorry to thread jack btw just have a similar question
__________________
Old 04-22-2007, 02:53 PM
correct assuming your b16 and ecu are obd0. unless youve done an obd1 conversion. obd0b16 ecu's= pr3/pw0
__________________
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
