HondaCivicForum.com
-   -   1998 DX Lowering Question... (https://www.hondacivicforum.com/forum/suspension-brakes-tires-wheels-14/1998-dx-lowering-question-40666/)
BigWorm Mar 22, 2007 05:22 PM
I have a 1998 Civic DX Sedan I just put 18" ADR wheels on it with a set of 215/35/18 tires.... the wheels are 42 offset...
I want to lower it and I know I need to go with a coil over setup and I was wonering what brand do you guys recomend...
Should I get the coil overs and shocks seperate or buy them as a set?
Thanks in advance...
BW
jhsplaya08 Mar 22, 2007 08:48 PM
RE: 1998 DX Lowering Question...
if i were you id pick up some koni yellow shocks/struts and ground control coilovers. adjustable and a really nice setup. cant wait to get mine on.....
ej6buddy Mar 22, 2007 11:35 PM
don't lower the vehicle to a great extent because you'll have problem's with your wheel/tire/offset. just as well, your ride wheel comfort will be horrible with that low of profile tire and suspension drop.
BigWorm Mar 23, 2007 06:49 AM
I don't plan on dropping it much more than 1" in the back and just a little more in the front... But I figure with coil overs if I ever change to 17" wheels I could drop it more...
III 4U2NV III Mar 23, 2007 09:26 AM
It's really up to you -- I have the Tokico HP spring/shock set and I have about 1" gap left all around (little less in the rear) and personally, I don't like it. I'm not a fan of wheel well gap at all. I personally would give up a a little bit of comfort for a NICE stance! It's all about what YOU want.;)
