AEM Short Ram Air Intake System
Login | |
AEM Short Ram Air Intake System - 3/23/2007 12:30:13 AM
ej6buddy
Distributor: 2Kracing.com Product: AEM Short Ram Air Intake System Car: 1996 - 2000 Honda Civic Dx (Fits Dx/Lx/Cx trims) Price: $112.00 Shipped (Currently priced at $124.00) Installation: The item was shipped in pieces in one box with all factory packaging. It included very precise directions, but the installation was very simple and straight forward. You first need to review the directions, then proceed with the installation. You first are going to need to remove the stock intake system (both black plastic boxes and tubing and brackets). Then you should have access to the throttle body. Then you can install the rubber mounting bolt to secure to the intake. Then assemble the intake by connecting the aem filter to the aem intake tube. Install the tube via the rubber tube connectors provided. Then secure the intake tube to the rubber mounting bracket. Then cut the intake vaccuum tube to length and install it from the intake tube to the valve cover. By using the provided rubber attachment, connect the sensor that was connected to the oem intake and install it onto the aem tube. Then use the provided coolant rubber hose and replace the factory hose with the one provided. Installation Time: 45 minutes - 60 minutes Review: I give this product a 5 out of 5. This product is well worth the money spent. There is an immediate noticable gain in horsepower, as well as sufficiently increased throttle response. The intake isn't much of a performance bolt on because the motor (d16y7) is one of the weaker engine platforms to work with. But the intake pays off in its looks and throttle response, as well as increased growl in the exhaust. At a certain throttle position, you can hear the whistling from inside the intake tube which is quite exilerating to hear when you are driving aggresively. Overall, i give this product an excellent rating because it's quality, fit, and finish are the very best. AEM really spends time on research and development on each application in order to have better quality control. With this intake system, you will not throw any cel problems, and it is C.A.R.B. exempt in all states (pending in California). Here is a picture of the product installed on my 1997 Honda Civic Dx Coupe: (Picture with the RTEC Polished Heat Shield installed)
_____________________________
RE: AEM Short Ram Air Intake System - 3/23/2007 1:34:38 AM
blackmetal619
looks good. i didnt know it was pending in california, i know the CAI is carb exempt
