Go Back   HondaCivicForum.com > Your Ride > Suspension, Brakes, Tires & Wheels
Reply
Old 03-24-2007, 02:02 AM
jhsplaya08 jhsplaya08 is offline
My Garage
Default my new stuff (FINISHED!!!!)
[align=left]check it out - - after 3 months of waiting, FINALLY i have everything i need. Skunk 2 front and rear camber kit, Koni Yellow Sport shocks and struts, and Ground Control coilovers. im hoping that me and my dad can install most of this ourselves but im going to be honest, i dont even know how the coilovers go on the shocks/struts. and which ones go on which? well is there any tips/advice...anything i need to know before installing? anything else i need?? take a look at the pics and tell me. i cant wait to lower it!!!
[IMG]local://upfiles/3700/1B5AF4A65157401287127DEDB54F0C80.jpg[/IMG]
[IMG]local://upfiles/3700/16A6BE7852E44C158E48392E81BFE209.jpg[/IMG] [/align]
__________________
Sponsored Links
Old 03-24-2007, 02:22 AM
Peg_Leg Peg_Leg is offline
Spammer Banner
My Garage
Default RE: my new stuff
very nice set up i think you will be happy with it, sorry i haven't installed coilovers before so i can't help you their good luck with the install
__________________
Old 03-24-2007, 02:31 AM
ej6buddy's Avatar
ej6buddy ej6buddy is online now
My Garage
installing is pretty straight forward. just get some extra bolts before the install in case the lca bolts break or seize up on you.
__________________
Old 03-24-2007, 02:39 AM
mxs's Avatar
mxs mxs is offline
Administrator
My Garage
awesome!
I sent you the link to the Koni install writeup, right?
first of all, throw away the silver spring perches. you don't need them. The shocks on the left are for the rear. Look at the springs, there is a series of 3 numbers on them. The last one is the spring rate. If you ordered standard rates, the higher one goes in the front. You will have to cut the bump stops in half, and trim the dust boot down to about 3". You'll also have to enlarge the hole in the dust boot for the Konis' larger shaft. Other than that... there should be instructions in the box with the Ground Controls, I think. You'll reuse the stock top hats, washers, and rubber bushings. Good luck with everything! I'll be away from the computer most of the weekend, but I'll check in at some point, so post here if you have any trouble.
__________________
Driving takes three abilities: Accelerating, braking, and turning. More power only helps acceleration. Lower weight helps all three.
PLEASE DON'T PM ME WITH TECH QUESTIONS, I WILL IGNORE YOU.
Old 03-24-2007, 10:58 AM
My Garage
thanks mxs, and yes you sent me a link. well hopefully i can attempt this tomorrow. what is the dust boot?
__________________
Old 03-24-2007, 12:47 PM
mxs's Avatar
mxs mxs is offline
Administrator
My Garage
It's this black plastic sleeve over the shaft of your stock shocks.
__________________
Old 03-24-2007, 08:33 PM
mill$civic mill$civic is offline
My Garage
Amazing! Lets see some install pics too. How much did it end up costing for everything?
__________________
Member since Feb 2005
Old 03-25-2007, 01:21 AM
My Garage
camber kit - $295 shipped off ebay and then the koni's and ground controls as a kit - $845 shipped from redshift. i think i got this stuff for a very good price. well tomorrow is the day ( actually today ) as it being 12:18 a.m. I really do hope i can do this and that everything works out good. mxs, when you put the sleeve on the koni shock or strut, doesnt the part have to slide over that stopping clip on the koni? ( you can turn it one way and it will set directly on it and then the other way it slides right over the clip thing and its hidden. im pretty sure this is the way it goes. )
__________________
Old 03-25-2007, 03:00 PM
mybrokenblinker mybrokenblinker is offline
My Garage
Ok, well i don't have that same setup, i dont hvae that kind of money (wish i did), but i did my setup myself, so ill check up and let me know if you have any questions and i might be able to help
__________________
ROTOZEY19111 (2:40:30 PM): I bought a bigass can of seafoam TRANNY treatment
ROTOZEY19111 (2:40:51 PM): and put that in my crankcase
Old 03-25-2007, 07:55 PM
My Garage
ok so in my picture, the ground controls on the right are for the rear? the spring rate is smaller and so are the springs. but the coilover part....the threaded part is longer than the other one. i figured this would go with the front ones. thats the way they were shipped though. is this correct?
__________________
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
