Go Back   HondaCivicForum.com > Your Ride > Suspension, Brakes, Tires & Wheels
Reply
Old 02-08-2005, 02:19 PM
89civiclx 89civiclx is offline
My Garage
Default Replacing stock struts question
Hello! Thread #2.... My first one was in the new section. So I have a 1989 Civic LX and the truts are dryrotting and worn out, they're probably stock... I want to replace the struts with something dependable for my son to use later. Then I look around in the forum and see Struts, Coilovers, Shocks, Strut bars etc.... I don't wan't the car to be a show car or race car, just dependable and sturdy. Don't need to drop it but if that happens (no more than 1") with no side effects, okay. Maybe some of you can make some suggestions; I know this is an older car that a lot of you don't deal with anymore, am I right?
Thanks in advance....
Jerome[sm=patriot.gif]
__________________
Stock 89 4dr LX with 64K mi. White with blue interior, new struts, trailing arm bushings.
Sponsored Links
Old 02-08-2005, 02:28 PM
Remmy Remmy is offline
Administrator
My Garage
Default RE: Replacing stock struts question
well you dont need anything that belongs in a ferrari. Just go to ebay and score a cheap set, you ought to get rear struts too. but if im wrong somebody should correct me.
__________________
Old 02-08-2005, 02:31 PM
Kappa22 Kappa22 is offline
My Garage
I would recommend two options. You can either go OEM, or KYB makes a pretty good OEM replacement that will tighten up the ride a little without changing anything else.
__________________
Your Forum Turbo Groupie...
Also your official Forum EF and GTR Brain-Trust
Old 02-08-2005, 07:44 PM
sacicons sacicons is offline
My Garage
yeah, KYB or a set (all 4) of Tokico Blues (HPs) that should make it handle a little better, but shouldnt set you back too much.
__________________
Quote:
ORIGINAL: Forty04
I choose the rear ending
Old 02-08-2005, 11:06 PM
My Garage
Thanx, I just looked around on EBay and saw those listed. . . . 'ppreciate the help.
__________________
Old 02-08-2005, 11:12 PM
My Garage
no problem, come on back whe you have another question, maybe we can help out your son by convincing you to put a few higher performance things on it
__________________
Quote:
ORIGINAL: Forty04
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
