We're adding and testing new features:  Create your Garage, used it? Give us some feedback here.
Go Back   HondaCivicForum.com > Your Ride > Suspension, Brakes, Tires & Wheels
Reply
Old 02-10-2005, 12:42 PM
mcbob mcbob is offline
My Garage
Default Need Solution For Sqweaky Brakes
My 94' Honda Civic EX has sqweaky brakes since I replaced them. I've tried that orange gel crap but it didn't do a thing. I was told to take a hacksaw and cut grooves in the pad itself. Not to sure what thats supposed to do but I'm willing to try anything. Any comments on my pad manipulation/mudulation idea?
Old 02-10-2005, 12:44 PM
Remmy Remmy is offline
Administrator
My Garage
Default RE: Need Solution For Sqweaky Brakes
there my be dirt or sand in the pads?
__________________
Old 02-10-2005, 01:27 PM
My Garage
Do you mean that there is dirt or sand in the pads from the manufactor or something I picked up from driving?
Old 02-10-2005, 08:30 PM
sacicons sacicons is offline
My Garage
did you use the gel correctly? a lot of people mess that stuff up. you gotta let it dry a little first. and also, what kind of pads did you get? some are louder than others.
__________________
Quote:
ORIGINAL: Forty04
I choose the rear ending
Old 02-10-2005, 08:43 PM
Kappa22 Kappa22 is offline
My Garage
Did you forget to transfer the anti-squeal plates to the new pads? A lot of people seem to make that mistake...
__________________
Your Forum Turbo Groupie...
Also your official Forum EF and GTR Brain-Trust
Old 02-10-2005, 09:01 PM
My Garage
Yeah, I used the gel on the pad and then put the anti-squeal plates on and then put more gel on top of that and let it dry for about 15 minutes. I also put gel on every little piece of metal that looked shiney from rubbing. The pads I bought were from Autozone so I'm sure their not the best. I was told that brake dust is the problem, thats where cutting slots into the pad comes in play. It's a pain in the ass to work on the car at my place so I go to the local car wash, it can be very interesting sometimes. I'll let ya'll know what happens!
Old 02-11-2005, 12:47 AM
fast97 fast97 is offline
My Garage
use a brake lube that is silcone base one the back of the pads and all of the brake caliper bolts a sqeak is cause by vibration between pads an rotors
__________________
too fast
Old 02-13-2005, 04:40 PM
Roost3r Roost3r is offline
My Garage
Send a message via AIM to Roost3r
if the sqweaking has just started recently then your pads could have picked up something when ur driving..also how new are the pads.. if they are starting to lose it all together..it might make that kinda noise
Old 02-13-2005, 09:09 PM
My Garage
and for what its worth, i cant see cutting slots in them doing much. maybe just pull them out and clean everything really well with a can of Brakleen.
__________________
Quote:
ORIGINAL: Forty04
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
