Go Back   HondaCivicForum.com > Your Ride > Transmission & Differential
Reply
Old 02-11-2005, 02:48 PM
AnakinKenobe AnakinKenobe is offline
Send a message via AIM to AnakinKenobe Send a message via Yahoo to AnakinKenobe
Default Goes in gear but no movement
Hey i got a 1995 honda civic ex coupe with a 5 speed tranny in it, just finshed an engine swap from a d16z6 to a jdm d15b, finally got the motor running and when i push the clutch in i put it in gear and let out the clutch and nothing happens, no moving or anything, i put a new clutch kit in it. any idea as to what the problem could be???
__________________
Hold her tight, had her last nite lol haha ....
Sponsored Links
Old 02-11-2005, 03:03 PM
Kappa22 Kappa22 is offline
Default RE: Goes in gear but no movement
A couple:
1) When you installed the clutch, did you set the control arm for the throwout bearing back in behind the disc? This would be highly unlikely.
2) Did you reconnect the shift linkage? I'm guessing this isn't the problem because you would notice a rather limp shifter. (I hate to play Captain Obvious, but it happens...)
3) Did you do a full clutch kit, or just the disc? If you only did the disc and didn't check the pressure plate or flywheel for wear, it could be worn enough to fail to engage.
I think there's more options that I'm forgetting, so I'll append if I think of any.
__________________
Your Forum Turbo Groupie...
Also your official Forum EF and GTR Brain-Trust
Old 02-11-2005, 05:14 PM
Yea linkage is perfect it goes in and out of gear on the tranny side, it was a full clutch kit and i basically did everything the book said im thinkin if i installed my the one plate backwards, but hey i still got the motor running
__________________
Old 02-11-2005, 05:17 PM
Well, you can't install the pressure plate backwards...
__________________
Old 02-11-2005, 05:19 PM
that little disc plate thing, whatever it is its keep the tranny from going into gear... hmmm????
__________________
Old 02-11-2005, 07:01 PM
sacicons sacicons is offline
oh, on the shifter? i thought you meant the CLUTCH disc, i was soooo confused. and i dont think you CAN install the clutch backwards in a civic, can you? i didnt think the spring side would fit in the other way.
__________________
Quote:
ORIGINAL: Forty04
I choose the rear ending
Old 02-11-2005, 07:30 PM
Yeah, that's what I said. It's impossible to bolt the pressure plate on backwards because the guidepin and bolt holes won't line up.
__________________
Old 02-11-2005, 09:25 PM
well what dou think could be the problem then, the tranny goes in gear but there is no moving..
__________________
Old 02-18-2005, 08:43 AM
PhilStubbs PhilStubbs is offline
Send a message via AIM to PhilStubbs Send a message via Yahoo to PhilStubbs
check your axles, you might have not put it into the tranny all the way
__________________
Quote:
ORIGINALCAcivic
philstubbs our master painter
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
