What do you guys recommend for 15-inch wheels that are less than 12 lbs each? The Traklite 2.0s (black with machined lip) are $232 each. Most of the $99 wheels are 15 lbs or more - too heavy!
__________________
1997 CX 5-speed
Eibach springs and shocks
Magnaflow cat-back
AEM V2 intake
16-inch Black Racing Pro wheels
Pillar Pod/tach/clock, Magnaflow and V2 install:
http://www.conceptualpolymer.com/honda_corner.htm
I think the Traklites are 10.8 lbs. Do you have a link for the Rotas with cost and weight?
Thanks!
__________________
1997 CX 5-speed
Magnaflow cat-back
AEM V2 intake
I think those are all-black and are being redesigned for a May release. I really like the polished/machined lip and black center. The benefits of super-light wheels are many - faster acceleration, much better ride, and longer-lasting brake pads, to name a few.
Dave
__________________
1997 CX 5-speed
Magnaflow cat-back
AEM V2 intake
that's just weight. The Slipstreams look like the only 15's under 12 pounds.
SSR Comps and Enkei RPF1's are light but not cheap.
Kosei K1's are relatively light and relatively cheap, as are Falken Hanabis
__________________
Driving takes three abilities: Accelerating, braking, and turning. More power only helps acceleration. Lower weight helps all three.
PLEASE DON'T PM ME WITH TECH QUESTIONS, I WILL IGNORE YOU.
The traklight 2.0's weight is listed in Tirerack.com. There is another Tracklite that is 11 lbs, but $232 each is kinda high!
Quote:
Rota slipstreams for the price and weight cannot be beaten.
:edit: Although I see these Flik wheels are the same thing.
I'll have to check those out!
__________________
1997 CX 5-speed
Magnaflow cat-back
AEM V2 intake
actually they can be beaten.
Falken Hanabi's. 15x7, 11lbs, at about $400 new.
i got my tires mounted last night but havnt been able to take a pic yet. there currently some damn snow on the ground which is rediculas, but i might put the wheels on my car later
sorry, I meant the slips are the only 15" ROTAS under 12 pounds.
__________________
