Go Back   HondaCivicForum.com > Your Ride > Audio/Visual Electronics
Reply
Old 04-09-2007, 01:06 PM
ScrooLoose ScrooLoose is offline
Default Will 6.5" speakers fit in my '95 Civic Hatchback ?
I have a '95 Civic Hatchback and atm i have the CDT CL-51 (5.25") compo set installed but i dont like what i'm hearing so i want to upgrade to some bigger speakers namely the CDT CL-62 wich are 6.5"
Somebody else who had some more experiance then me installed my whole audio system (Dragster Audio Art DAB 4160 amp, CDT CL-51 compo set and a Kicker comp 12 sub)
He said that 6.5" speakers would not fit properly without modifying the door a bit, so i chose the smaller speakers at that time, but since i dont like the sounds they produce i want some better speakers.
Unfortunately i cant find the precize demensions the 6.5" CL-62 speakers have so i dont know if it will fit, so can anyone here tell me if it will fit without having to modify the doors ?
Does anybody have 6.5" speakers installed without having to modify the doors ?
Sponsored Links
Old 04-09-2007, 01:41 PM
Roadkillboy0 Roadkillboy0 is offline
Send a message via AIM to Roadkillboy0
Default RE: Will 6.5" speakers fit in my '95 Civic Hatchback ?
Yep it 6 1/2s should do the trick. http://cardiscountstereos.com/SpeakerGuide15.asp double check that website though
__________________
My Stock Exhaust
Old 04-09-2007, 02:53 PM
Mounting depth is going to be a problem with the speakers i want according to that list, mounting depth is 1" 7/8 according to that list and the speaker mounting depth is 2,6" .....
But how do they measure that, is that the distance from the surface u put ur speakers on to the inside of the outer door panel ?
Could prolly fix that by putting the speaker on a MDF ring maybe....
Have to do some measuring tomorrow then.
Cheers
Old 04-09-2007, 05:05 PM
theonecalledtodd theonecalledtodd is offline
dont quote me, but i think youll be fine without rings or anyhing like that. My friend has a 94 civic and alpine type-X's in the doors. Those fit no problem without a hitch so im sure youll be ok...... worst case though, ring it up, just dont make it so think that the speaker cover wont fit.[align=left] [/align]
__________________
with love, Todd
project, 95' Del Sol-- the ugly duckling
1998 honda civic EX 4-door (yes 4!!!)
5-speed manual
D16Y8
Old 04-11-2007, 08:52 AM
Well i did some measuring and they will fit but i cant turn the windows completely down then
And even if do use rings the windows probably wont go down completely since the mounting depth of the speakers i want is 2.7", and if i make the rings too think i cant get the covers on anymore [sm=smiley21.gif]
But i'm hoping this is all temporary since i;m looking for a new car, looking at Honda Preludes atm, the ones made between '96 and '01, and if they wont fit in there properly either i will just have to modify the doors
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
