Honda Civic Forum   Classifieds   Photo Gallery   Member List   Calendars   Search   Contact Us   Sponsors
  Honda Civic News   Forum FAQ   Timeslips   Civic History   Recalls   TSBs   Register   Login
Help! Can't shift after engine start
  Printable Version
Honda Civic Forum >> Your Ride >> Transmission & Differential >> Help! Can't shift after engine start Page: [1] 2 3   next >   >>
Login
Message << Older Topic   Newer Topic >>
Help! Can't shift after engine start - 2/13/2005 11:02:34 PM
machot
Status: offline
I have '94 Civic EX Coupe 5 Speed. After I start the engine and try to shift, I am not able to put into any gear. Also, when I step on the clutch it feels different. It's hard to explain in words, but it feels "off". Does anyone know what is wrong with it and/or how to fix it? Thank you. T
Post #: 1
RE: Help! Can't shift after engine start - 2/14/2005 12:28:48 AM
se7ensectoolate
Status: offline
se7ensectoolate's photo gallery
Grind gears often? Couldve bent your shift fork or messed up your synchros.
(in reply to machot)
Post #: 2
RE: Help! Can't shift after engine start - 2/14/2005 12:35:09 AM
D16z6
Status: offline
D16z6's photo gallery
Make sure that you push the clutch completely WAY down to the floor. I stall my car on a crowded road before and when i tried to turn it on it won't turn on. I was like **** i better get out and start pushing but it turn out that i didn't push the clutch all the way down to the floor.
_____________________________
A
(in reply to se7ensectoolate)
Post #: 3
RE: Help! Can't shift after engine start - 2/14/2005 12:37:11 AM
sacicons
Status: online
sacicons's photo gallery
no, it sounds like a clutch problem. try to decribe the feel a little better. did it just happen? or was it a gradual thing? was your clutch slipping at all before?
quote:
ORIGINAL: Forty04
I choose the rear ending
Post #: 4
RE: Help! Can't shift after engine start - 2/14/2005 2:47:14 AM
Remmy
Status: offline
Remmy's photo gallery
you know as strange as this sounds it might be the problem. When I was young my father had an accord, 94' actually. My mother spilled coke on the shifter all summer long... in the winter my dad would turn the car on to take me to school and he would sit there and fight the shifter for 5 minutes every time. The dealer told him the old sticky coke got down there and would freeze causing the shifter to "lock" .
(in reply to sacicons)
Post #: 5
RE: Help! Can't shift after engine start - 2/14/2005 4:42:22 AM
99civic_boosted
Status: offline
I would lean towards a faulty master or slave. If either one is bad or low on fluid, the clutch will not depress all the way preventing the car from going into gear. Seen it many times.
Post #: 6
RE: Help! Can't shift after engine start - 2/14/2005 3:39:23 PM
grncivicvtec
Status: offline
IS grinding the gears, like say when you are shifting and while putting it into letrs say 4th the clutch is not al the way in and a load sound happens and it wont go into gear, thats grinding? and how bad is that.
00' Civic Ex,
B18B1 Ls non-Vtec
Stock internals so far
upgraded clutch
N1 Exhaust
Coilovers
still pimpin on bo bo's
(in reply to 99civic_boosted)
Post #: 7
RE: Help! Can't shift after engine start - 2/14/2005 7:45:06 PM
sacicons
Status: online
i think we need more info. im leaning toward the master or slave as well, but its hard to tell without more info. check the fluid level. is it low?
quote:
ORIGINAL: Forty04
(in reply to grncivicvtec)
Post #: 8
RE: Help! Can't shift after engine start - 2/14/2005 10:31:27 PM
Remmy
Status: offline
Im leaning more towards the coke spill down the drive shaft
Post #: 9
RE: Help! Can't shift after engine start - 2/14/2005 11:00:05 PM
sacicons
Status: online
shifter shaft?
quote:
ORIGINAL: Forty04
(in reply to Remmy)
Post #: 10
Login OR Register now to post a reply to this forum topic.
Honda Civic >> Your Ride >> Transmission & Differential
Jump to:
Featured Sponsors
Go
Advertising Info
Top 10 Posters
forty0414258
remmy11165
fiirkan10543
mill$civic8473
marty8273
mxs8006
fliphkd7207739
nail i3unny7705
sacicons7699
addiction2ba7489
New Vendors
K&N Engineering, Inc.
