Go Back   HondaCivicForum.com > Your Ride > Transmission & Differential
Reply
Old 02-14-2005, 09:03 PM
gillespiecd gillespiecd is offline
Default clutch issues
Initially I had difficulty shifting gears so I had my master clutch cylinder replaced. Soon after I was losing power after driving my car longer distances-over 20 minutes. I thought my clutch was going but my mechanic bled the clutch, and my car had power again. So my mechanic told me that I had air leaking into the clutch system. They couldn't determine where, nothing was obvious to them. So they changed the slave cylinder thinking it could the culprit. However my car is still doing it! After driving for more than 20 minutes, I lose power, not just on hills, and in all gears. It sounds as though it's slipping. After my car sits over night, it drives fine the next day for the first little while, when it's cold. My clutch fluid is full so I don't think I'm losing fluid.
Its a 1995 Honda Civic with 230,000km on it and it's never had a clutch put in it because it was mostly hwy driven. Should I just ask my mechanic to change the clutch anyway, since I am probably overdue? Help! [sm=dontgetit.gif]
__________________
CG
Sponsored Links
Old 02-14-2005, 09:09 PM
sacicons sacicons is offline
Default RE: clutch issues
thats really odd. i think its more than time for a clutch, but i dont like telling people to throw parts at a problem. but its losing power? or the clutch is slipping? i dont get it. if its actually losing power, the clutch shouldnt have anything to do with it.
__________________
Quote:
ORIGINAL: Forty04
I choose the rear ending
Old 02-14-2005, 09:14 PM
XCM828 XCM828 is offline
I think it probably feels as though he is loosing power because the clutch is slipping. He pushes the gas, car doesn't go forward as fast. When you try to accelerate while in gear, does the engine rev higher but you don't go forward?
__________________
And for all you VTECHers out there: Please Click
HCF Map!
Old 02-14-2005, 09:16 PM
Kappa22 Kappa22 is offline
Well, I've run into a problem like this before, but it was with an Accord, not a Civic, so I don't know how much relevance it will bear here. Those hydraulic clutches are a REAL pain in the ass to bleed right (not just a simple, "pump it up and hold it" kinda deal), so if you had any air in the line, it could be causing this... If I remember right, there's a bleeder line front and center, and you have to create vacuum and suck fluid UP into the system (that might not be completely right; I might go check the ol' manual).
But once again, all that was on an Accord, so I don't know if it'll be of any use.
__________________
Your Forum Turbo Groupie...
Also your official Forum EF and GTR Brain-Trust
Old 02-14-2005, 09:55 PM
no, the civic clutch bleeders work just like a brake bleeder. well, doing it manually anyway, i dont know about those auto bleeder things. but its just two people, and one works the valve, and one works the pedal.
__________________
Quote:
ORIGINAL: Forty04
Old 02-14-2005, 11:27 PM
Yeah, that's what I figured...
__________________
Old 02-14-2005, 11:36 PM
i was walking into autozone one day, and i stopped to help these girls put new wiper blades on their Jetta, (in the rain, it would have been fun to just watch, but i felt bad.) and so on the way in, this guy with a 5th gen sedan stopped me and asked where the clutch fluid goes. i pointed it out, and then started walking in when i thought about it and went back and asked him how low it was. well, it was empty. so i told him to wait, and i went and bought the 8mm wrench i needed, and came back out and helped him bleed it, as he was clueless. it was funny, cause i grew up in a small town where everyone did stuff like that for other people, and this guy just couldnt believe i went out of my way to help him. he thought i worked at autozone. i was just like " no, but i have almost the same car, so i had to help." and i pointed to mine. then he thanked me a couple times, and i left.
it is realy that easy to bleed the clutch, but if the fluid level isnt dropping, thats not the problem, air has to get in somewhere, adn the resevoir is the only place ive ever seen it get in.
__________________
Quote:
ORIGINAL: Forty04
Old 02-15-2005, 09:22 AM
red91civicDX red91civicDX is offline
It SOUNDS like the clutch is getting hot and slipping, much like a torque converter on an automatic when it gets tired. But ultimately, you have to rule out the air in the system thing before it comes to diagnosing a worn clutch plate. Does the pedal FEEL any different in resistance? If it does, that would indicate an air/bleeding problem. If not, it may point more towards time to get the wallet out and buy the round thingy that lets the motor thingy turn the trans thing and the round black things on the front of your car.
__________________
_________________________
1991 Honda Civic DX, 225,000 original miles
1993 Supercharged Pontiac Bonneville SSEi
Old 02-15-2005, 02:11 PM
A steering wheel??
(Just playin'...)
__________________
Old 03-12-2005, 10:07 PM
96 civic 96 civic is offline
how can you tell when the clutch is about to go
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
