Honda Civic Forum   Classifieds   Photo Gallery   Member List   Calendars   Search   Contact Us   Sponsors
  Honda Civic News   Forum FAQ   Timeslips   Civic History   Recalls   TSBs   Register   Login
91 Civic Shocks / Strut Replacement by Droopy128
  Printable Version
Honda Civic >> General Automotive >> DIY - Do It Yourself >> Drivetrain DIYs >> 91 Civic Shocks / Strut Replacement by Droopy128 Page: [1]
Login
Message << Older Topic   Newer Topic >>
91 Civic Shocks / Strut Replacement by Droopy128 - 4/18/2007 1:10:33 PM
Patrick
Status: offline
Patrick's photo gallery
Just did my 91 civic front and rear shocks replacement.  However, I only posted the front, because other have post a DIY for the rear already, and my method is as follow:
Once the car is on jack stand with wheel off from the car.
Remove the bolts holding the brake line to the struts.
Follow by removing the bolt on the fork of strut.
NO PIX – In order for me to remove the whole unit including the fork, I have remove the lower arm nut / pin and the axle hub nut (33mm).  As to how you would remove the axle from the vehicle.
After all the bolts and nuts are remove from the axle / strut, then remove the 2 nuts on top of damper housing, the shock unit will drop and remove it from the vehicle.
Remove the bolt on the fork to separate the fork from the strut.
Use spring compressor to compress the spring and remove the bolt on top of the shock, remove the damper and slide the old shock.
NOTE:  remember the alignment mark on damper when reinstall, because you will not be able to turn it once the spring is un-compressed.
Reinstall in reverse order ..!
_____________________________
Revisions: 1 | Post #: 1
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Honda Civic Forum >> General Automotive >> DIY - Do It Yourself >> Drivetrain DIYs
Jump to:
Featured Sponsors
Go
Advertising Info
Top 10 Posters
forty0414155
remmy11161
fiirkan10322
mill$civic8433
marty8262
mxs8005
nail i3unny7705
sacicons7674
fliphkd7207589
pete7169
New Vendors
K&N Engineering, Inc.
