Go Back   HondaCivicForum.com > Your Ride > Engine & Internal > Swap Meet > EG Swaps
Reply
Old 04-21-2007, 06:32 AM
SE_2_EG SE_2_EG is offline
Default h23 in EG
I'm considering swapping in an h23. I found a 94 si that was hit on the side. Hes asking 600 and the motor runs good. I know i need mounts but since i have a complete car will i need any wiring harnesses or would it be better to take it right off the si? And I was thinking about using the the brakes too but i'm not sure if they will fit or not. Any info would help thanks.
Sponsored Links
Old 04-21-2007, 12:54 PM
drbyers drbyers is offline
Default RE: h23 in EG
take EVERYTHING off the si. and keep it around while doing your swap, if you can, because you may need something.
as for as the brake swap, that's a good question.
i've seen civics with NSX brake swaps, so anything is possible.
__________________
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
