We're adding and testing new features:  Create your Garage, used it? Give us some feedback here.
Go Back   HondaCivicForum.com > Your Ride > Suspension, Brakes, Tires & Wheels
Reply
Old 04-22-2007, 03:26 AM
zhmendak zhmendak is offline
My Garage
Default Steering wheel shakes when brakes are applied
Hi,
I have 95 civic DX coupe. I have a bad problem with my brakes, when I apply them my steering wheel shakes like hell. I replaced my rotors 2 times already and the problem is still there. When I did the brake job last year I had to replace left caliper because it was stuck and when I tried to put new pads in the caliper was blocking them so my wheelwould spin it would spinlittle bit and that get stuck. So I was wondering if I screw up my pads too because I drove with that caliper for about 10 miles while I was testing the brakes. Some people told me that the problem might be in the front struts, but I am not sure if that has to do with anythingbrakes. Also my brake pedal pulsates when i brake. Can it be suspension?
Guys please help me!
__________________
Ukranian's_drive_civics!
Old 04-22-2007, 12:51 PM
AgentofDarkness AgentofDarkness is offline
My Garage
Send a message via AIM to AgentofDarkness
Default RE: Steering wheel shakes when brakes are applied
Usually steering wheel shimmy is caused by warped rotors. I would check both calipers and make sure that they are not sticking. Also pull the rotors off and take them to a machine shop/parts store and have them checked if they are warped. What might be happening is your calipers are sticking and this causing the rotors to overheat and warp.
__________________
HCF Chat Rocks!!!!
Reply
Tags
2005, applied, apply, applying, brake, brakes, civic, honda, shake, shakes, shimmy, steering, sterring, stteering, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
