My car is laggin
Login | |
RE: My car is laggin - 4/24/2007 8:10:22 AM
jwsimons
you notced the low performance after the headers were installed????? cause what you describe sounds like its not breathing well untill it gets up enough poweer to suck hard enough to get air.... check your air filter, in fact do a tune-up.... plugss, cap, rotor, wires, etc.
_____________________________
getting there is half the fun, do it yourself
RE: My car is laggin - 4/24/2007 10:14:28 AM
riceburner700
ok, First of go to an exhaust shop and have them weld in a second 02 bung, you should have a o2 before and after your cat. Second change your oil and filter, couldnt hurt. Third replace your cat if it needs it, it could be clogged hince hurting your performance. maybe try a tune up as well
non-vtec ALL THE WAY cylinder head guru!
RE: My car is laggin - 4/24/2007 11:06:16 AM
zoso
There are two 02 sensors, one in the car that goes up into the car, thats the secondary. The primary one is in the middle of the header, i have that end plugged in, where do i plug the square part it is the other end?
RE: My car is laggin - 4/24/2007 11:07:33 AM
riceburner700
do you have a pic?
RE: My car is laggin - 4/24/2007 12:11:26 PM
Forty04
quote:
ORIGINAL: zoso There are two 02 sensors, one in the car that goes up into the car, thats the secondary. The primary one is in the middle of the header, i have that end plugged in, where do i plug the square part it is the other end? Dig around in the engine bay, there is another plug that looks shockingly similar to the one you have, and go figure, they connect!
Don''''t PM me with tech questions Antartic Blue Super Sports wagon with C.B. and optional Rally Fun Pack
RE: My car is laggin - 4/24/2007 6:21:21 PM
zoso
Ha really where would this plug be around?
