We're adding and testing new features:  Create your Garage, used it? Give us some feedback here.
Go Back   HondaCivicForum.com > Your Ride > Audio/Visual Electronics
Reply
Old 04-24-2007, 10:46 PM
thi3v3z thi3v3z is offline
My Garage
Default Wire up 4 channel amp
How do i wire up a diamond audio d6300.4 to run 150rms x 2 @ 4 ohms? how many rcas do i need, 2 or a 4 channel? Do i need the amp to run in 2 channel mode, or have it run in 4 channel and bridge? Do i run it with channel 3/4 mono on or off?
Old 04-24-2007, 11:44 PM
the727kid the727kid is offline
My Garage
Send a message via AIM to the727kid Send a message via Yahoo to the727kid
Default RE: Wire up 4 channel amp
You need to have one set of RCAs coming from your front outputs, and then have splitters right before the amp and put it into all 4 channels. Then for the left speaker use the far left and far right outputs on channels 1 and 2, and the same thing for the right channel except channesl 3 and 4. I would imagine your run it with all channels on but if there is a switch for bridged, choose that.
Old 04-25-2007, 06:14 PM
civicduty96's Avatar
civicduty96 civicduty96 is offline
My Garage
if you have componets you should run em active , cause i do belive d6 amps have bandpass crossovers.
just a thought.
__________________
stage 1 boosted b16 ... blew up before it could hit the dyno
stage 2 built and boosted b16 ... 267 whp
stage 3 in progress
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
