buzzing noise
when i play my radio or cd...i get this buzzin noise...its an engine interferrance...i already tried those ground blocker relay things....and it still there...anyone got a clue on how to get rid of it?? maybe a new set of hyper grounds will work??
RE: buzzing noise
You running an amp with subs? If so be sure the power wires are run seperatly from the other wires. If not, could be wiring behind the deck or ignition interferance. A good set of plug wires might help.
RE: buzzing noise
double check all your hookups ide say. make sure the ground is good
RE: buzzing noise
I had the same problem when i first hooked up the system... it was the grounds...be sure there all good
.......good luck |
RE: buzzing noise
grounds to what?? the engine or the system?? i've done a new ground on the engine...and it still makes that sound...
RE: buzzing noise
ORIGINAL: ntxmotorsports be sure the power wires are run seperatly from the other wires |
RE: buzzing noise
check all of them but i think it would have been the engine because if its the ground to the system / amp/ your bass wont hit... the ground to my system was pulled out and the amp/sub hookup stoped working... i guess if you checked the gronds then thats not the problem...
good luck with the problem. |
RE: buzzing noise
yea, first check ur grounds... if you grounded on a painted surface, did you grind off the paint? make sure ur power wires aren't run near speaker or rca's. gl.
| All times are GMT -8. The time now is 01:57 PM. |
