Go Back   HondaCivicForum.com > Your Ride > Audio/Visual Electronics
Reply
Old 06-20-2004, 10:12 PM
GWhiz GWhiz is offline
Default buzzing noise
when i play my radio or cd...i get this buzzin noise...its an engine interferrance...i already tried those ground blocker relay things....and it still there...anyone got a clue on how to get rid of it?? maybe a new set of hyper grounds will work??
__________________
Til next time...payce...one...g...outro
Sponsored Links
Old 06-21-2004, 03:58 PM
NTX NTX is offline
Default RE: buzzing noise
You running an amp with subs? If so be sure the power wires are run seperatly from the other wires. If not, could be wiring behind the deck or ignition interferance. A good set of plug wires might help.
__________________
Apexi Boost Gauge, Apexi Meter Control Unit, RMR C/F Gauge Pod, Blitz Fatt DC III, Rexpeed Apex VG
Old 06-21-2004, 05:04 PM
green98lxsedan green98lxsedan is offline
double check all your hookups ide say. make sure the ground is good
__________________
gone but not forgotten 98 civic lx sedan
RIP 3/23/05
current garage
04 nissan armada le
01mustang gt
blown, intercooled, and cammed
04 acura tl
98 4runner
Old 06-22-2004, 02:38 AM
ohbiskits ohbiskits is offline
Send a message via AIM to ohbiskits
I had the same problem when i first hooked up the system... it was the grounds...be sure there all good
.......good luck
Old 06-22-2004, 04:45 AM
grounds to what?? the engine or the system?? i've done a new ground on the engine...and it still makes that sound...
__________________
Old 06-22-2004, 08:07 AM
polo708 polo708 is offline
Send a message via AIM to polo708
Quote:
ORIGINAL: ntxmotorsports
I'd bet that is exactly what it is... its your power wire (from your amp) running too close to your speaker wire... My cousin has that problem but hes too lazy to fix it. Just re-run either of the two to a different location away from eachother.[sm=smiley2.gif]
__________________
-brian
Old 06-22-2004, 03:20 PM
check all of them but i think it would have been the engine because if its the ground to the system / amp/ your bass wont hit... the ground to my system was pulled out and the amp/sub hookup stoped working... i guess if you checked the gronds then thats not the problem...
good luck with the problem.
Old 08-15-2004, 09:43 AM
eggie75 eggie75 is offline
yea, first check ur grounds... if you grounded on a painted surface, did you grind off the paint? make sure ur power wires aren't run near speaker or rca's. gl.
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
