Im looking to buy an Apexi WS2 exhaust. The only one close to my car is for a 92-00 Civic Coupe EX. Now my question is, will this exhaust fit my 94 CoupeDX?
yes, but you will since your cat is built into your exhaust manifold, you can either get a new header, cat, and the exhaust, or you can get some sort of test pipe to run from your header to meet the exhaust because as is they won't meet. Normally the order is, going away from the engine
Header===>catalytic converter===>exhaust
But since yours has the cat in the header, right now if you got the exhaust it would be
Header===> =====>exhaust.
You need some kind of piping to fill the gap, or you need to switch to an ex header, cat, and exhaust.
__________________
ROTOZEY19111 (2:40:30 PM): I bought a bigass can of seafoam TRANNY treatment
ROTOZEY19111 (2:40:51 PM): and put that in my crankcase
Yes it will fit, i have a CX and the only one for a hatch is the SI, the only difference would be the exhaust manifold/cat. the catback should be the same
