Go Back   HondaCivicForum.com > Your Ride > ECU Tuning & Fuel Management
Reply
Old 02-17-2005, 09:47 AM
hans747 hans747 is offline
Default Idle system problem Code: P0505
Hello,
I'm helping a friend of mine with her 99 Civic. A few days ago, the started idling irradically. When it does this, acceleration is very bad as well. She says that the problem will go away if she turns off the engine and restarts it immediately. While getting some other work done, her mechanic checked the codes and came up with this:
Code: P0505 -- Idle system problem
Unfortunately, the mechanic did not tell her what needs to be fixed. What components should be checked?
Here are my guesses, (keep in mindthat I've never dealt with Hondas before):
EGR valve
Throttle position sensor
She just dumped a ton of money into CV Joints and tie rods, so any easy DIY suggestions would be helpful.
Thanks,
Eric
Sponsored Links
Old 02-17-2005, 09:56 AM
Roost3r Roost3r is offline
Send a message via AIM to Roost3r
Default RE: Idle system problem Code: P0505
uh..kappa ,sacicons ..wanna hadle this????
Old 02-17-2005, 08:34 PM
XCM828 XCM828 is offline
Check the IACV and all sensors. Make sure there are no vacuum leaks.
__________________
And for all you VTECHers out there: Please Click
HCF Map!
Old 02-17-2005, 09:34 PM
Not familiar with IACV I'm guessing it stands for Idle (blank) Control Valve. How close am I?
As far as checking the sensors goes, what's the best way to do that? Which sensors do the computer consider part of the Idle control system?
Thanks,
Eric
Old 02-17-2005, 11:06 PM
Idle Air Control Valve
Basically you need to check all the sensors that run to the PCM (vehicle speed sensor, coolant temp. sensor, air conditioning sensors, power steering pressure sensor, etc.) because the PCM adjusts the idle based on the info it receives from these sensors. You can do visual checks on the sensors to check for damage or corrosion. But make sure you check for vacuum leaks too.
__________________
HCF Map!
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
