RE: XM vs. Serius and Aux input on '07
I use XM satellite radio just like you said. Magnet antenna on the roof, that i routed through the trunk, and along back windshield, and put it right in the center about 6inches from the window. Connect the power to the power outlet under the dash or in the center console. Connect the audio output to the AUX input under the dash of my civic and it works great. Just make sure to set the ouput level on the XM radio so that it is about even with your CD player audio. First time I switched over and nearly blew out my ears cause I had my satellite radio output set so low.
__________________
DAMM: Drunks Against MADD Mothers
