Go Back   HondaCivicForum.com > Your Ride > Engine & Internal
Reply
Old 06-21-2004, 09:47 AM
ohbiskits ohbiskits is offline
My Garage
Send a message via AIM to ohbiskits
Default dpfi to mpfi
I heard that the best mod i could do to my 91 honda civic hach stock motor 1.5 liter is to put multi point fuel injection on it... is this true? Does anyone know if i were to do this is it going to be a noticeable increase? Alos could someone tell me exactly what i would need to do this, This guy i was talking to this guy in front of pep boys told me to put a 92- 95 civic intake manifold and wireing harnes w/ mustang injectors... i just need the info if this is right or not
please help
Sponsored Links
Old 06-21-2004, 12:46 PM
polo708 polo708 is offline
My Garage
Send a message via AIM to polo708
Default RE: dpfi to mpfi
I dont know about the best mod, but its a good mod. The best mod would be turbo/supercharger/or nitrous... something along those lines. Multi port fuel injection will take some time and probably run you some bucks.
__________________
-brian
Old 06-21-2004, 03:24 PM
NTX NTX is offline
My Garage
You'll need the injectors, intake manifold, wiring and ecu from a mpfi civic. It would probably be easyier to just drop in an 1.6 ex engine from a 96-98.
__________________
Apexi Boost Gauge, Apexi Meter Control Unit, RMR C/F Gauge Pod, Blitz Fatt DC III, Rexpeed Apex VG
Old 06-21-2004, 05:03 PM
My Garage
Quote:
ORIGINAL: ntxmotorsports
How much is that engine swap gunna run me and is that cost worth it?
thanks for the help
Old 06-21-2004, 05:45 PM
NTX NTX is offline
My Garage
if you drop the ex engine in, you'll have mpfi and vtec all at the same time and because its not a dohc the cost will not be as great (you can probably find everything you'll need at a recycler for a few hundred).
__________________
Old 06-21-2004, 10:27 PM
My Garage
thanks for the info i may look into that...
Old 06-21-2004, 10:47 PM
My Garage
i forgot... can you tell me everything i need to do that swap... also is that motor going to bolt right into my bay or will i need to do anything...
i have a little overe 200 000 mi on my engine so its probably a good idea to do the sawp rather then rebuild right... i dont have the biggest budget either...but who does right.
thanks
Old 06-22-2004, 01:50 AM
NTX NTX is offline
My Garage
With 200k you should do a rebuild if you want to run it hard. The swap would require some wiring, ecu and some mounts. You'll more than likley need some axles also.
The rebuild would more than likely be the more cost effective way to go.
__________________
Old 06-22-2004, 01:59 AM
My Garage
yea that sounds good i have this on another post in the nos turbo supper... forum but ill say it in this one too... i was thinking just to mod my engine and put all new internals as i get the money... what do you think about this a good idea?
Old 06-22-2004, 02:25 AM
NTX NTX is offline
My Garage
new internals (crank, pistons and rods) in a 1.5 is gonna be costly and you won't get the power you could get with a swap but if you want to keep that motor and turbo it or add nos, you will have to strengthen the bottom end and add the mpfi.
I still think the 1.6 vtec is a good cost effective way to go. There are a lot of turbo kits and supercharger kits already out there for it.
__________________
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
