HondaCivicForum.com
-   -   wiring a neon (https://www.hondacivicforum.com/forum/audio-visual-electronics-10/wiring-neon-43401/)
jr000 May 1, 2007 12:06 PM
wiring a neon
okay i am going to put neons in my trunk i have a switch that has a battery,accesory,and ground input on the bottom...could somebody tell me how to wire it with the switch...or a diagram would be even better...thanks
addiction2bass May 1, 2007 07:02 PM
RE: wiring a neon
a switch doesnt have those inputs.....
its got a input and output... and IF its got a light built into it THEN it has a ground wire.
you can always tie into the latches ground pin switch and just use it to activate the lights in the trunk.
