Go Back   HondaCivicForum.com > Your Ride > Transmission & Differential
Reply
Old 05-01-2007, 08:46 PM
kash kash is offline
My Garage
Send a message via AIM to kash
Default What transmission Works?
I wanted to know exactly what transmissions work with a d16z6 engine because my third gear is poppin out and i figure that i should just get a new one?
Thanks everybody all ideas are greatly appericated.
Sponsored Links
Old 05-01-2007, 08:55 PM
danomatic93's Avatar
danomatic93 danomatic93 is offline
My Garage
Send a message via AIM to danomatic93
Default RE: What transmission Works?
any hydraulic D-series tranny (the zc is an exception, but you can make it work) from a 92-00 civic. Make sure it's a D-series tranny (SOHC!, not DOHC). If you have a z6, I would reccomend getting another Z6 tranny (92-95 EX/Si) or "upgrade" to a D16Y8 tranny (96-00 civic EX/Si).
Tranny's will have a code by the trans fluid fill plug that reads A000 or B000. A000 has small bearing case and B000 has large bearing case. So, B000 is better.
Here's where you can find the code:
A000's are from HX, DX, CX, VX models [gear ratios better for high end]
B000's are from EX, Si (SOHC only) models [gears ratio better for low end]
The Y8 tranny is "better" because it's composed of steel instead of aluminum like the Z6.
Also, the Y8 has one gear that has a slightly higher gear ratio than the Z6.
Z6 M/T gear ratios: Y8 M/T gear ratios:
1ST: 3.250 1ST: 3.250
2ND: 1.900 2ND: 1.909
3RD: 1.250 3RD: 1.250
4TH: 0.909 4TH: 0.909
5TH: 0.702 5TH: 0.702
Reverse: 3.153 Reverse: 3.153
Final Drive: 4.250 Final Drive: 4.250
I recommend getting a B000 and a Y8 if you can get one.
Old 12-02-2007, 06:32 PM
Bizz Bizz is offline
My Garage
to whom it may concern,
Will a B000 work with a 97 civic Dx.
My 5th gear is going out. I'm on the cheap, a buddy gave me a B000 tranny and I'd like a shop to put it.
Thanks,
Eugene
Old 12-02-2007, 07:08 PM
My Garage
Quote:
ORIGINAL: danomatic93
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
