Quote:
ORIGINAL: FrankieBermudez
Sup! Quick question! How far can you push a B16Y8 engine before you blow the SOB? Also, I want to throw in a Cold Air Intake System. Any suggestions on a good manufacturer. By the way, it's a 2000 Civic EX-5sp, 2-Dr Coupe. It's fun driving it! Hollar back!!
I believe you are refering to the D16Y8 unless you have a swapped engine and in that case it would be a B16 (A or B)
The D16Y8 has more then a lot of people will give. I have the same motor turboed at 8 lbs of boost. And you think yours is fun to drive!!!
As for the Cold air - IMO - I have not been impressed with one over the other. It really comes down to the filter. Make sure its a good one. If you live in a wet area consider getting a bypass valve to prevent water from getting sucked up and killing your engine.
