Honda Civic Forum   Classifieds   Photo Gallery   Member List   Calendars   Search   Contact Us   Sponsors
  Honda Civic News   Forum FAQ   Timeslips   Civic History   Recalls   TSBs   Register   Login
Front sway bar a diy by brokenarmboy19
  Printable Version
Honda Civic Forum >> General Automotive >> DIY - Do It Yourself >> Drivetrain DIYs >> Front sway bar a diy by brokenarmboy19 Page: [1]
Login
Message << Older Topic   Newer Topic >>
Front sway bar a diy by brokenarmboy19 - 5/28/2007 12:29:44 AM
brokenarmboy19
Status: offline
brokenarmboy19's photo gallery
Ok guys its diy time I am going to tell you how to install an aftermarket front sway bar first things first you are going to need a 12mm wrench a 14mm wrench and a cheater bar and a beer for any job you need the proper tools ok the beer is not necessary but it helps
make sure your lower control arms have a hole in them (see pic 1)
take tires off (trust me it makes putting the end links on way easier) and jack up the car
unbolt exhaust at the cat (refer to pic 2)
unbolt shift stabilizer and let hang (refer to pic 3 and 4)
unbolt shift linkage (pic 5)
lubricate urethane bushings and place on the sway bar
place sway bar in its place with the hump above exhaust and shift linkages
place aluminum spacer under bushing and the steel u shaped piece over the top of the bushing and bolt them in place on both sides longer bolt goes on the side that is thicker (pics 6 and 7)
lubricate end links and bolt in to place through holes in lca’s make sure not to over tighten you wand them to just start to bulge over tightening can cause a failure
reattach your exhaust and shift linkages
put your tires back on and lower your car
Enjoy your new flat handling
    < Message edited by Forty04 -- 5/31/2007 12:25:22 PM >
    _____________________________
    quote:
    ORIGINAL: WhiteRabbit1021
    presto-chango, poop in a condom.
    Revisions: 1 | Post #: 1
    Login OR Register now to post a reply to this forum topic.
    Page:   [1]
    Honda Civic >> General Automotive >> DIY - Do It Yourself >> Drivetrain DIYs
    Jump to:
    Featured Sponsors
    Go
    Advertising Info
    Top 10 Posters
    forty0414155
    remmy11161
    fiirkan10322
    mill$civic8433
    marty8262
    mxs8005
    nail i3unny7705
    sacicons7674
    fliphkd7207589
    pete7169
    New Vendors
    K&N Engineering, Inc.
