RE: wiring up fogs need help
The male/female spade connectors just allow you to unhook, and reconnect. Butt connectors, or solder and tape will do a better job. Wire up some relays UNDER the hood, and use the switch to throw a ground to turn the lights on. That way you don't need to take 12 volts thru the fire wall. The lights are outside and up front.....and so is your battery!
__________________
Quit your complaining, if your stupid..... your stupid.
It's not MY fault! Blame your parents.
